General Category => Anim8or v0.98 Discussion Forum => Topic started by: maxxarcher on June 27, 2008, 09:09:15 am
Title: Selection in Object/Edit mode
Post by: maxxarcher on June 27, 2008, 09:09:15 am
Hi Steve,
I´ve been using Anim8or off and on since version 6.something and always wondered why selection of an object gets switched off when an edit button gets selected. Currently I´m toying around with a lot of small objects trying to create a mockup for a real-world project I´m working on. Lots of moving and resizing going on, meaning either a lot of keyboard handling or a mouse pointer running around the screen jumping back and forth between selection/editing buttons and objects.
Why not have the selection mode always active, next to a selected edit mode? It seems obvious to me that when an object has already been selected, the selected edit mode is active. When not selected, selection takes place. Extra option: when both selection buttons are depressed, the edit mode is locked and accidental re-selection is not possible.
I always ignored this logic, until I had a shoulder operation last week which immobilizes my left arm for the time being. The keyboard/mouse handling suddenly becomes quit obvious...
Cheers, Maxx
Title: Re: Selection in Object/Edit mode
Post by: xalener on June 30, 2008, 12:58:46 am
I don't know. That would be a pretty drastic change to a UI that a lot of people are occustomed to. I'm sure newbies and pro's alike will be confused.
Post by: maxxarcher on July 04, 2008, 07:03:41 am
Drastic? Hardly I think, it would actually be more intuitive and userfriendly. Moreover, most 3D (and 2D) programs/suits work like this, which would make life another bit easier when switching between programs...
Post by: hihosilver on July 04, 2008, 02:04:46 pm
maxxarcher:  My guidance for now would be to keep your left hand on the ctrl and shift keys.  If you press "ctrl + shift", anim8or will switch to the select tool as long as you hold it down.  It's really useful.
Post by: Steve on July 06, 2008, 05:02:56 pm
When I first started working on Anim8or, selection was always on similar to what you suggest.  But a lot of people had problems with it, especially beginners.  For example, they'd carefully select some faces and then try to apply a tool.  But if they missed a selcted face instead of using the tool Anim8or would drop the existing selections and select the new face.  So I changed it.  Now you know if you're selecting or editing and can't do the wrong thing.
Post by: thecolclough on July 07, 2008, 06:48:44 am
how about a switchable selection-always-on mode for people whose left hand has been disabled for some reason or another, eg. maxxarcher?  i wouldn't use it myself normally, but if other people want it then it might be worth looking in to ;)
- colclough
