General Category => General Anim8or Forum => Topic started by: tobbe654 on April 28, 2008, 03:33:03 pm
when i try to fill holes it dont work every time. sometimes i need to make a lot of diagonals to get it working..
i guess that isn't necessary..
is it a bug in anim8or?
(http://img380.imageshack.us/img380/8351/animhhi5.th.jpg) (http://img380.imageshack.us/my.php?image=animhhi5.jpg)
thanks for answers
that's a pretty odd-looking wireframe... :P could you post your .an8 file for us to have a look at, maybe?
my only diagnosis so far is, it looks like you might be trying to attach more than 2 faces to the same edge, which isn't possible. :-\
welcome to the forum, btw ;D
- colclough
here it is: http://home.no.net/rfadum/tobbe/hybel.an8 (http://home.no.net/rfadum/tobbe/hybel.an8) right click --> "save as" (or something like that..)
- colclough
yes, thats what im trying to do.. is it any reason for thats inpossible??
else its really weird, isn't it?
had a look at your file, seems to be some problems ...make two boxes then in face mode use inset , where you want door to be and then delete the face, heres the file back all you need do is join them .
you are as colclough suggests trying to join different edges and the fill holes option will not work as you have it set up.... You should`nt need all those tris in the small floor either.
Hope this helps!
anim8or doesn't allow more than 2 faces on the same edge, because otherwise some of the faces would end up being buried inside the mesh, which usually isn't worth it (you wouldn't be able to see them), and i think limiting it to 2 per edge probably also makes it much easier for the program to work out where faces should be put in.
if the object's going to be a building, then it'd probably be better to make it out of several thin cuboid solids, rather than building it from faces in a mesh. real walls and things have thickness, and using cuboids would show that more realistically. and i think it'd be easier, too. anyway, that's how i always make my building models, i find it works quite well for me. :)
- colclough
yes, but this is just a demo for my presentation.. i wanted to make something quick.. not a big project..
oftopic: take a look at my bigger project: http://home.no.net/rfadum/tobbe/unnamed.an8 (http://home.no.net/rfadum/tobbe/unnamed.an8) rightclick --> "save as"..
To help you understand I made this visual. Hopefully it's more clear now...
(http://img185.imageshack.us/img185/5691/facesne5.gif)
As a side note, you can tell how many faces are already connected to an edge. If the edge is pink when selected, there are no faces connected to it. If the edge is green when selected that means it has one face connected to it, and when an edge is white that means it already has two faces connected to it, so you can't attach any other faces to it unless you delete one.
Edit: The last sentence in the image should say "green edge" not "orange edge"
but that's what i was saying - cuboid primitives are pretty quick to work with. at least, i find they are, i guess not everyone's the same though...
