General Category => General Anim8or Forum => Topic started by: Sagadali523 on September 28, 2022, 04:16:55 pm
Hey, I got a trouble with Anim8or. After I painted the human model and going to sequence mode, I moved the hand and I saw that the finger got glitched. Any help? I'll provide you a both picture
https://cdn.discordapp.com/attachments/1008552937552871555/1024746336014303302/unknown.png
https://cdn.discordapp.com/attachments/1008552937552871555/1024774915519430736/unknown.png
Thanks
Best Regards
-Sajad Sadiq
In the first picture, showing the colors, go to wireframe view.
The paint attaches to the vertices. (points). If you zoom in and around a bit and have a close look at the vertices on the glitchy fingers, you'll see where you've missed a point. It will be a different color than it should be. (a point is not stuck to the bone, so when you move the finger, the point doesn't move with it) It's a common thing, you just need to have a closer look to find the offending point.
Otherwise, looking good :)
It didn't work. It still got glitched.
OK. Either try again, or post your file and i'll take some snapshots of where the problems are, so you'll have a better idea at recognising what to look for.
You could try repainting the second and third fingers. Just repaint over top of what you have already done, there's a good chance you'll catch the ones you've missed.
In this video, at about 5.22, it shows where the hand has a 'glitch', and how i fixed it. What you've got is the same type of thing.
I'll give you my model. Go to the sequence mode and move the right arm and you'll see the finger glitched. You can also move the left arm and you'll see another finger glitched.
Ok, cool. Found the problem.
You can set the strength and size of the weight brush by going 'Build -> Weight brush' (figure mode)
I've entered a strength of 1, and a radius of 12. and gone over the glitchy parts of the fingers again. (fixed).
The rest looks ok.
By changing strength to 1, i gave it 'maximum stick'.
Being able to change size of brush is really handy for little and 'close together' things. ;)
Thank you, Johnar.
Welcome. :)
