General Category => General Anim8or Forum => Topic started by: jbskaggs on January 11, 2021, 11:35:08 am
Title: Is it possible to have no background on render?
Post by: jbskaggs on January 11, 2021, 11:35:08 am
As post title says: us it possible to render no background just the object?
Title: Re: Is it possible to have no background on render?
Post by: Steve on January 11, 2021, 12:52:44 pm
Do you mean in the scene editor or another editor? You can turn off the checkerboard ground in the Scene editor with the Scene Properties->Environment dialog.
Or do you mean make it transparent (alpha = 0)? You can do that when you render by checking the "Image+Alpha Channel" option.
Post by: jbskaggs on January 11, 2021, 05:42:19 pm
Ill try this. I, trying to eliminate having to manually delete the background from png renders to import in 2d engines.
Post by: jbskaggs on January 11, 2021, 07:32:18 pm
Worked perfectly.  Now on to figuring out how to set the poses at same size and angle for each cardinal direction.
I remember you added a pivot point to make this easier or at least fixed a pivot crash bug.
Now I need to look at scripting and see if my chemo addled brain can make sense of it.
Post by: ENSONIQ5 on January 11, 2021, 09:36:29 pm
I'm not entirely sure what your ultimate goal is so I may be off the mark, in which case I apologise in advance.  Rather than rotating the figure to obtain your eight cardinal-point views it might be easier to 'orbit' the camera around a static figure.  In Scene mode this could be done by placing a target helper object at the rotational centre of the figure and making it the parent of the camera.  With the camera set at an appropriate distance from the figure, rotating the target helper object in 45-degree steps in an 8-frame animation would sweep the camera around the object through each of the cardinal points.  Render to a set of still images and you have your set of 8 images for the figure.
Post by: jbskaggs on January 11, 2021, 10:17:58 pm
Thank you that might work as well!
Post by: Steve on January 12, 2021, 08:34:49 am
Here's a project with the camera's position controlled by a script. It rotates around the origin every 8 frames at the 8 points of a compass. You can control the height and the distancefrom the ground by moving the target object around on the screen. (I also added a strange objects for the camera to see, but you'll probably want to replace it with your rabbit.)
Post by: jbskaggs on January 12, 2021, 12:12:40 pm
I can run the scene.  How do I run the script?  I dont see it in the file.
Thanks!
Post by: Steve on January 12, 2021, 12:32:46 pm
The script is part of the camera's position. Double click on the camera, then click on the "..." next to the location, then on the "Edit" button at the bottom of the Kep Position dialog. This will bring up the script.
Post by: jbskaggs on January 12, 2021, 01:32:01 pm
Thanks!
BTW I shared the link to your website on the game engines forums Im a member of.
I appreciate all your help and consistency!
