General Category => General Anim8or Forum => Topic started by: daren_Anim8or on November 10, 2020, 08:24:30 am
Title: Is it possible...
Post by: daren_Anim8or on November 10, 2020, 08:24:30 am
Is it possible to change the opacity settings for the figure or sequence editor of the model?
Thanks
Title: Re: Is it possible...
Post by: AlecJames on November 11, 2020, 04:32:36 am
The transparency is set on a material so to fade a figure you would need to change the transparency of every material used on each object of your figure.
So the quick answer is no.
But if you really had to:
I've assumed you want to make a figure fade out of a scene by changing the opacity settings.
I tried to do this with a controller script, but I couldn't because the material.alpha and material.[attribute functions] that I wanted to use only appear to work in object mode, I get a script error in scene mode when I try to use them.  Maybe someone else could suggest a way to modify the material.alpha from a controller script?
This leaves two options -
1) have multiple figures, e.g. 10.  each with a different level of transparency.  Then use visibility keys to change figures so they fade out.  This involves loads of work,  I wouldn't do it this way unless 2 does not work.  The only reason I can think of for 2 not working is if you have multiple figures all fading in / out with the sequences overlapping.
2) Use the visibility key to make the figure disappear where you need it to fade.  After rendering to video, split the clip (using a video editor) where the figure disappears and add a cross fade.
Post by: daren_Anim8or on November 14, 2020, 05:14:28 pm
Thanks
