General Category => Anim8or v0.98 Discussion Forum => Topic started by: Tanzim on April 15, 2008, 01:39:52 am
Title: Bone Issues
Post by: Tanzim on April 15, 2008, 01:39:52 am
So heres my problem: I've made this rig but I accidentally forgot to add the 'wrist' bone, so I have 2 choices: either move all the bones move simultaneously in sequence mode or do it all over (deleting the fingers and then adding the wrist)
(http://img144.imageshack.us/img144/920/handrigproblemch5.jpg)
So what I want is a tool that can add parent bones to a child bone, I'm sure many of you have had this same problem before.
Title: Re: Bone Issues
Post by: hihosilver on April 15, 2008, 02:08:38 am
There's a solution to this problem.  It's actually very easy.
Select the arm bone that you want to build the wrist bone onto, then go, "build>insert bone" and you can insert a bone on top of this one.  You can then resize the rest of your bones to a proper length and rotate them correctly and you should be golden!
Post by: Tanzim on April 15, 2008, 03:21:24 am
Thanks a lot :)
