General Category => Anim8or v1.0 Discussion Forum => Topic started by: selden on September 01, 2017, 06:40:49 pm
When using Anim8or v1.0b, in the Object editor, if I try to custom rotate a centered cylinder by 45 degrees, it instead rotates some small angle. The builtin 90 degree rotations work OK. The problem is seen for all rotation axes.
This problem is not seen in Anim8or v1.0: a custom rotation of 45 degrees works fine.
Here are a couple of screengrabs of 1.0 and 1.0b after a custom 45 degree rotation about the Z axis.
I dealed with that in v.1.0 a even, I think. Custom rotation about 180 , 90 and other angles.
I found the problem so it'll be fixed in the next build.
Thanks!
Yup: fixed in v1.0b 1298!
