General Category => General Anim8or Forum => Topic started by: Blick Fang on August 31, 2017, 03:56:08 pm
Title: Texture scaling issue
Post by: Blick Fang on August 31, 2017, 03:56:08 pm
Hi
I am adding a texture to a surface and instead of seeing one instance I see 4 of the textures.  I tried quadrupling the Wand H in the texture map to no avail.  Searched the forums and found nothing relevant which I found strange
Help?
Thanks!
Title: Re: Texture scaling issue
Post by: Steve on August 31, 2017, 05:40:01 pm
How did you make the surface? Can you post a picture of it?
Post by: Blick Fang on September 01, 2017, 12:02:04 pm
Hi Steve
I added the an8 file and the 2 textures also.  The tweet texture would be applied to the large object (the speaker cabinet).
Post by: Steve on September 01, 2017, 01:12:50 pm
The reason that there are 4 copies of the texture is that the UV coordinates for the texture specify that. It does not matter what size the actual texture image is, the UV coordinates specify a relative position in the image, what percent across or up and down, to apply to a face.
You can resize the texture using the UV tool in the Point editor.
1. First select only the faces with the texture you want to rescale.
2. Then click on the UV button and
3. click Yes in the dialog to enable texture UV generation for the object.
4. Click drag in the middle of the big yellow circle on the screen with the MIDDLE mouse button to rescale the texture. Use the RIGHT mouse button to move it if it's off center.
Post by: BlueDalek on September 01, 2017, 01:25:29 pm
Looks like a guitar amp you drew.
Post by: Blick Fang on September 01, 2017, 01:47:25 pm
Thanks Steve
BlueDalek, actually its a 3D model I downloaded
Post by: kreator on September 01, 2017, 04:20:59 pm
BlueDalek:  Haha! Thats A cheeky pun Arthur!
Basic beginners Error when using Anim8or`s UV tool there Andy! I am sure you could do better yourself than relying on a downloaded model my friend
Post by: Blick Fang on September 01, 2017, 04:28:13 pm
Kevin
Funny you should mention that....
the only issue I am having is when I add the speakers; they get lost in the grill.  You'll notice that happened to the side handlws but its no big deal.  And I also noticed before I closed Anim8or I goofed up my work.  I can't give it my best attention because I am at work and have to keep hiding Anim8or
Post by: kreator on September 02, 2017, 02:21:10 am
 :)  Got it to upload finally!   Andy some enhancements to your file, I dunno if you wanted this boombox animated but you can add concentric rings to the front face of the box then morph them in and out. I added the speaker but don`t really think it is necessary  as you will not see it ( Unless of course your Pete Townsend from "The Who"
Post by: Blick Fang on September 02, 2017, 04:32:59 pm
Kevin thats awesome!  And the grill is perfect!
Thanks!!
