General Category => Anim8or v1.0 Discussion Forum => Topic started by: danielstritt on March 28, 2017, 10:32:38 am
When I open the movie image properties dialog, and click inside "other" edit box, but don't type anything in, then click any other preset frame rate, I get an error that says "frame rate: malformed number". This may show up once, or infinitely and I have to kill anim8or with task manager. Keep in mind I don't click the "Other" radio box, just the edit box, then one of the presets.
Version 1.00 Beta 22-march-2017
Thanks for the bug report. That dialog gets confused when the aspect ratio fields aren't valid numbers. I'll fix it so this doesn't happen unless you check the "Other Fixed Aspect:" button and then enter something invalid.
Note: this should be fixed in v1.0 beta 2 (http://www.anim8or.com/download/beta/animv100beta2.zip).
Yes, it appears to be fixed. Thanks!
