General Category => General Anim8or Forum => Topic started by: Hypure on January 01, 2016, 11:06:54 pm
Is it possible to connect a point to an edge creating two edges? And Is it possible to remove points without losing an edge?
Yes, select the edge, then do a shift/Z to cut the edge this will give you another point
Yes again, move the point you wish to remove very close to an existing point, then do a shift/L and type in an appropriate number for the tolerance (default 0.50) and it will merge the two points together. If it does not, either move the point closer or use a higher number.
That helps, thanks kreator.
