General Category => Anim8or v0.98 Discussion Forum => Topic started by: Hypure on December 26, 2015, 04:44:38 pm
Title: add keyframe without affecting current position
Post by: Hypure on December 26, 2015, 04:44:38 pm
I thought in scene mode I could click the work space with current tool and it would lay down a keyframe for current position, I thought Anim8or did this but not anymore?
Title: Re: add keyframe without affecting current position
Post by: Raxx on December 26, 2015, 07:02:57 pm
I recall it doing so as well, but with the addition of the Fast Select tool, I think it would have caused a bit of unintended keying of elements.
If you want to key the current position/orientation/scale/whatever, you can double click on its spot in the timeline and hit "Add Key".
Post by: Hypure on December 26, 2015, 08:30:16 pm
Ok all the same, thanks. Speaking of the fast select I discovered the usefulness of that as well.... and Raxx, I was watching your tWEAK v0.1b vid on youtube, It looked like you were working with a "heads up display" toggle for your tools on Anim8or... That looks great, did you ever release that?
Post by: Raxx on December 26, 2015, 10:59:52 pm
Wow, been a while since it's been brought up. The release topic for tWEAK is located here (http://www.anim8or.com/smf/index.php/topic,3769.msg27222.html), and it probably won't work with anything except 0.97, especially if you're using the new UI in Anim8or. I actually used it a lot in some of my old modeling projects, like seen in my youtube.com/watch?v=MtbSbcMaAcY[/youtube]]frog modeling (https://www.[youtube) video.
But that was a while ago. A good many of its features, like Alt to rotate the view, tweak tool, and quick knife, have already been implemented in the newer Anim8or releases by Steve. While the radial menu and a few of its shortcuts are still pretty useful, I'd have to rebuild it from scratch if I were to revisit the project. It's on my to-do list, right next to "Render Manager", "Anim8or 3D Viewer", "An8Hub", and "An8 File Converter" :P
Post by: Hypure on December 28, 2015, 03:29:43 pm
Well you are Boss second only too Zen master Steve, the "alt-view rotate" is great..  Your "render manager" sounds great, currently I have been rendering (problem) scenes as frames in a single folder then exporting those to a second program where I find the frames that have the shadows "reversed" and render those frames individually then replace the bad frames.....  Tedious but not really if you only have a few frames to replace......  But that "radial menu" is superb, I would put that on the top of my most wanted!  I could only imagine hitting a hot key for that-  AND if those buttons on the radial menu were programmable?!!  I'll stop dreaming now.
