General Category => Anim8or v0.98 Discussion Forum => Topic started by: Sluggs on December 01, 2015, 07:32:58 am
During my time with Anim8or, I've noticed some weird thing going off when taking screenshots of the work area...
This is what I just did...
I created a 1x1x1 cube and then copied it twice, each time doubling it, so I ended up with 3 cubes...
1 x 1x1x1
1 x 2x2x2
1 x 4x4x4
Now, when I take a screenshot of the work area then paste it into my paint program, the sizes of the cubes are as follows...
The 1x1x1 = 4x4 pixels (Correct)
The 2x2x2 cube = 8x8 pixels (Correct)
The 4x4x4 cube = 18x18 (Should be 16x16 pixels)
Also, sometimes when I have made a cube and took a screenshot of it, it's one number of pixels on one side, and another number of pixels on another side.
What's happening?
Note: My desktop resolution is set to 1024x768 if that makes any difference.
This is cause by the way that OpenGL samples polygons when it renders. The pixel is only drawn if the center of it is covered by a polygon. In you case the 4x4x4 cube just barely covers the centers of the additional pixels. Move it around and the size will probably go from 16<->17<->18.
If you make an anti aliased render you see softer edges with partially covered pixels.
I don't really understand this much, but I thought it might be something else that's causing it, and it not being a problem with Anim8or itself, but if you don't ask...
Also, yeah! I've noticed the pixel counts changing when moving the same cube around! :-)
Thanks Steve!
