General Category => ASL Scripts => Topic started by: selden on October 28, 2015, 07:05:33 pm
How can I retrieve the BlendMode associated with a Texture in the export script that I'm working on?
(I'm trying to improve the functionality of my CMOD export script.)
The documentation at http://anim8or.com/scripts/spec/index.html shows "int GetBlendMode(int mode);" to be an element of "struct material" except that can't be right. That would allow only one BlendMode per material, while there actually can be many BlendModes in a material, one associated with each of a Material's Textures. Unfortunately, my attempts to retrieve it as if it were an element of a texture structure don't work. :(
Try:
int GetBlendMode(int kind, int mode);
If it's implemented, it should be similar to
int SetBlendMode(int kind, int mode);
There is a typo in the spec. The real description should be:
int material.GetBlendMode(int kind);
where kind is one of:
enum {
TEXTURE_AMBIENT,
TEXTURE_DIFFUSE,
TEXTURE_SPECULAR,
TEXTURE_EMISSIVE,
TEXTURE_TRANSPARENCY,
TEXTURE_BUMPMAP,
TEXTURE_ENVIRONMENT,
and the return value:
enum BlendMode {
BLEND_MODE_DECAL = 0,
BLEND_MODE_DARKEN = 1,
BLEND_MODE_LIGHTEN = 2,
An example:
mode = lMaterial.GetBlendMode(TEXTURE_DIFFUSE);
I didn't think about this long enough to see that
int mode was not required,but I was wondering
what int SetBlendMode() and int SetAlphaMode()
would return.
Steve,
Thanks, a lot! That did exactly what I wanted. I was able implement "decal" and "darken". Unfortunately, Celestia does not provide a way to add colors, only multiply, so I was unable to implement "lighten".
The revised CMOD exporter is now available at http://www.classe.cornell.edu/~seb/celestia/modelling.html#4.1
