General Category => Anim8or v0.98 Discussion Forum => Topic started by: johnar on January 10, 2015, 08:56:56 am
Heres a curly one, discovered while trying to work out why builds 1140 through to 1150 will not open some of my an8 files.
I've attached a zip with 2 small files, and this explanation, as below.
An8Files: Identical.
Ballfig1.an8: Object is named 'object01. Figure is named 'figure01'
Ballfig2.an8: Object is named 'ball'. Figure is named 'figure01'
Problem:
Anim8or 1140 to 1150.
Will import figure from Ballfig1 but Will NOT import figure from Ballfig2.
Have tried several variations of object and figure name changes
Can import figure if figure name is changed from 'figure01', but cannot import figure if object is named anything other than 'object01'.
Any Anim8or pre 1140 will import from both.
Can anyone replicate please?.
EDit: can actually open the files, but just not import the figure.
Windows7 home basic 32bit .
Sounds like a bug. I'll look into it.
Cool. Thanks steve. :)
johnar: I never got back to you this. But it seems to be fixed starting at build 1167.
Thanks for looking into that steve.
Yes indeedy. I've just tried it on some more recent builds and the problem does seem to be fixed.
Nice one. (http://s24.postimg.org/o4uvmxwjl/Thumbs_Up_G1.gif)
