General Category => Ongoing Anim8or Development => Topic started by: Steve on November 27, 2014, 02:12:31 pm
I'm updating Point Edit mode fairly drastically. It's long overdue. This is a big job and I think it's reached a point where it's better than before. Please bear with me on during the transition. The major changes are:
Simultaneous editing of Points, Edges and Faces: You can enable any or all of these together.
Dynamic Highlighting: With Fast Select enabled the Point, Edge or Face currently under the mouse is highlighted in red. This makes it easier to see what will happen when you click the mouse. There is a top menu button to toggle Fast Select, hot key <Ctrl-T>. I'm not 100% happy with the red color so let me know what you think.
Thick Edges: An option in the File->ConfigureUI dialog uses thicker lines to draw edges. Try this together with antialiased workspaces for a great look, especially on larger screens.
Consistent of Mouse Buttons: I've changed the use of the mouse buttons to be more consistent. For example, previously for Arrow Select the left mouse button (LMB) selected one item and deselected the precious ones, the MMB deselected only that one thing, and the RMB added to the selection. For Move the LMB moved things in the plain of the screen, the MMB in the direction of the normals, and the RMB into the screen. The new behavior makes everything act like Arrow Select. Now you can press the <Ctrl> key to move in the direction of the normal.
Space Bar Deslelects: now the <Space> bar deselects everything as it does in the rest of Anim8or.
Smart Selection: You can select only what you can see. In wireframe Points have priority over Edges, over Faces. This allows you to select points and edges in the back part of something. (Of course you can still disable front and backside components with the [Front] and [Back] buttons.) In solid views the closest thing to the view is selected so you don't accidentally select a hidden edge, etc. If edges or points aren't drawn (are disabled in the UI settings dialog) then the aren't selected by the mouse.
Rotate and Scale tools: I haven't changed these yet except in the way things are selected. My original "pivot" idea simply doesn't work. So in the coming days I'm changing them to be more intuitive. Stay tuned...
Hot key T: toggles through point, edge, face select modes. I intended to have a 4th state that enabled all 3 but forgot to add it for this build.
OK, give the new Point Editor a try and let me know what you think!
Hmm can no longer close a quad to create a face in Point edit mode..... why??? or am I missing something !!
This is critical to modelling with anim8or.
Erk, yeah I have this problem as well. That is, the add edge tool doesn't snap to other points anymore.
Also, disabling thick lines doesn't save between sessions.
looks very sexy....whats the f box symbol for?
I like the red highlight.
Hmm can no longer close a quad to create a face in Point edit mode. Yes, I'll fix this and post it tomorrow. Ate too much turkey today to do it just now!
disabling thick lines doesn't save between sessions. I have this fixed, too - I used slightly different names to save and restore the setting in the registry.
looks like anim8or is jumping ahead in leaps and bounds congrats Steve
Moving in Z doesn't work.
Moving in Z doesn't work. Yes, that's a consequence of making the mouse usage more consistent:
"For Move the LMB moved things in the plain of the screen, the MMB in the direction of the normals, and the RMB into the screen. The new behavior makes everything act like Arrow Select."
I'm still experimenting with ways to support Z axis movement.
Have you considered introducing 4 toggle-while-held hotkeys (ideally, in a row on the keyboard) for All, X, Y, Z? This method doesn't have to interfere with the click-to-toggle action of the XYZ graphical buttons and can be independent.
F5–F8 perhaps?
I posted build 1138 with these issues fixed.
nemyax: As for moving in the Z direction, I have a temporary solution to get you going again. When only the Z axis is enabled the point-edit move tool moves along the Z axis. You can use the "T" hot key to rotate through the enables in this order: PEF->P->E->F->PEF.
headwax: You have some nice work on your blog. Some days I feel like it's "The Year I went Rusty" for myself!
Thanks.
What was your pivot idea that didn't work out? Or do you mean the way things stand now?
nemyax: Yes, the way things stand now. Rotating and scaling is currently done around the Pivot, the zero coordinate point of the mesh. You can move it and rotate it in Pivot Edit mode, but it's rather difficult to know how to position it so that point move in a predictable way.
I think it's much more intuitive to edit work in the current view, based on what you've selected, or in world coordinates. So stay tuned and be sure to let me know what you think about the changes!
Absolutely. Also, each uninterrupted piece of selection should rotate and scale about its own centre. That's a very intelligent default, but not all modelling software has latched on. It took Blender until last year to get support for that option.
Interestingly, that would make the Rotate Faces and Scale Faces tools redundant, because those would just be regular transforms.
"Fast Select/thick lines" very cool usefull!!
Thanks Steve!
Yes, I plan on removing the Rotate Faces and Scale Faces tools.
I am LOVING the ability to be able to select and move with the same tool, however I think it should have a new icon (one with cursor and move symbol combined).
Say Steve are you planning on adding a variable for the thickness of a line; you know one that the user can have control over. In other words have line thickness as a text box and you put a number in for its thickness (1 would default to 1 pixel width).
I will have to play around with it some more to be of anymore help :P but I'm too tired right now ;)
cooldude234: I hadn't planned on a setting for the width, just the enable (width = 2) / disable (width = 1) like there is now. If people think it would be useful I can always add it :)
Steve If you remove these items how do you plan to implement, I am having trouble with visualising this at the moment.
For Rotate Faces, you just rotate them about their normals. In the current build's control scheme, you hold down Ctrl for a normal-based transform. For Scale Faces, you just scale them uniformly.
These particular transforms don't need special treatment when a consistent system is in place. And it should work equally well for transforming edges and faces using whatever axis you choose.
Scale will work the same way, but better because it will scale relative to the selected points, not to the pivot. At least I hope it will be better!
Hey Steve, I really like the increased pick tolerance. Feels a lot more natural!
I guess I'll repost here some of my thoughts on the new system, if anyone would like to give input on it, they are more than welcome to.
- It'd be nice for the option to use thick lines just for highlighting and maybe selection, so that it only helps it stand out more on a mesh while editing. Global thick lines otherwise kind of obscure the form and structure of the mesh, making it harder to work with when doing detailed modeling where such form and structure is necessary.
- A lot of times, a point is visually clipped by the surrounding geometry (like in a concave convergence of faces). I think if a point is selected or highlighted, it should show the entire point unclipped, then go back to normal otherwise.
- One bug I've noticed, if the mesh exceeds the boundary of the view, and you move the mouse from mesh to, say, the top toolbar, whatever face/edge/point was being highlighted before the cursor hits the toolbar, remains highlighted. In fact, sometimes moving the mouse back and forth from face to toolbar highlights other previously highlighted faces as well.
- I think it'd be nice that, when Fast Select is toggled on, if the move, rotate, or scale/non-uniform scale tools are not already selected, then it'll automatically enable the move tool by default. Otherwise it'll use whichever of the four tools that is already selected.
- I think the behavior of the right- and middle- click after dragging should abandon the add/subtract functionality. That is, if just single-clicking, then it does the selection functionality (single select for LMB, subtract for MMB, add for RMB). If dragging, it should have the same transformation functionality as the normal move/rotate/scale--but not affect the selection. So if I right-click-dragged, it wouldn't add onto the selection and transform it at the same time--it'd just transform the current selection. If click-dragging on an unselected element, it selects and transforms just that element. This is the easiest behavior to understand on the user-end, I think...
- I'm feeling a bit conflicted about the Ctrl-click-dragging functionality of Fast Select. I think if Ctrl is held down, it should paint the selection the same as in select mode, regardless of if the move/rotate/scale tool is enabled, rather than transforming along the normal. Transforming along the normal is a nice tool to have on special occasion, but it's also only useful for point editing--it's hard to use with faces and edges. I think it'd be most useful to move this back to MMB with the move tool.
In an attempt to recap what these mouse buttons do and possible suggestions:
- Move:
- LMB moves normally
- CTRL+LMB moves along normal. Would be good to remove this.
- RMB moves towards/away from camera (or, used to in regular point edit mode. This is still useful)
- CTRL+RMB moves along normal. Would be good to remove this.
- MMB nothing. Would be good to make it move along normal
- CTRL+MMB moves along normal. Would be good to remove this.
- Scale:
- LMB scales normally-ish. Perhaps change this to midpoint scaling
- RMB nothing yet. Perhaps scale with origin as pivot?
- MMB nothing yet. Perhaps change this to pivot scaling?
- Rotate:
- LMB rotates normally-ish. Perhaps change this to midpoint rotating
- RMB rotates on plane of camera (however you describe it--useful).
- MMB nothing yet. Perhaps rotate around pivot?
- The bit about the Ctrl modifier key and mouse buttons kind of brings up some issues. Most notably, the issue of consistency and just how the modifier keys should behave. This might need to be reserved for another conversation though...
[edit]As for highlight color, red feels a bit stark to me and kind of disrupts that in-the-zone modeling zen thing. I think a yellow-orange (R:255, G:132, B:0) might work well, among other things :)
Raxx, amazing color interface! Simple and Beauty!
Yes that is a good GUI Raxx!
Raxx: You have lots of good ideas, as usual. Here's some preliminary thoughts/comments.
Use thick lines just for highlighting and maybe selection.
I agree that this could be useful but it's more work that you might think. That's not to say I don't want to do it.
Show entire point unclipped when selecting.
That was my intention - I'm still working on the best way to do it.
Moving the mouse off the main window leaves a point/edge/face highlighted.
I'm aware of this but haven't yet found a good way to address it yet either.
behavior of the right- and middle- mouse buttons
I'm still working on how these should behave. There are a lot of options. You can't distinguish between a click and a drag until the user either moves the mouse or releases the button. The way that I would do this is:
1) On Mouse Down: Do nothing. The current P/E/F if there is one should already be highlighted.
2A) On Mouse Move: Remove the highlighting. If the highlighted P/E/F is unselected, deselect the rest of the object and select just that part. The continue begin editing the mesh. What happens if you click in empty space? Deselect everything? Or edit using the existing selection(s)?
2B) On Mouse Up: If the mouse hasn't moved, Clear-and-Select, Deselect-One or Add-Select, depending on the button.
Currently on 1) I remove the highlighting and effect the selection.
highlight color
Yes, As I stated in the top of this topic the overall colors are as yet decided. Your example looks really good but it shows a monochrome mesh which isn't the norm. (On a related note: One idea I have is for a setting that shows everything as a light gray. Seems that this would be useful for modeling because the shape is a bit more obvious.)
I know it's more work, but I think it's worth it! So I'll wait and hope ;)
Yes, that's my thinking as well :) If you click (or click and drag) in empty space, it should deselect and do nothing.
highlight color
Personally, for 99.9% of the modeling I do, I use a gray material. The orange otherwise has as much chance of standing out as any other color (well, you know, unless you consider that bright green catches the eye most of any color, but bright orange is closer to it than red). It would indeed be awesome to have a modeling view option, that gives it a slightly darker gray than the default material (flat, no spec), and also does a "Headlight" effect, where the only light source is from the camera, thus illuminating the mesh no matter the viewing angle. This is my favorite in other modeling programs, and an extremely helpful aid to modeling.
I personally kinda question the general wisdom of those "deselect all on empty space click" points of view.
Deselection a (small or potential big) active selection by accident is not something that you would like to happen to easily. Clicking in empty space with the mouse, while editing a selection with the mouse, seems a not to uncommon possible mishap.
(Deselecting all with SPACE, and only with SPACE. Has a lot less change of being used accidentally.)
Also, To me, using different mouse buttons for different selection actions seem a bit of a wast of mouse button use. When using the selection status of the clicked item to add or remove is to or from the current section ... would only require one mouse button, leaving the others mouse buttons for potential other functions. (+having a strong memorable difference between the usage of the different mouse buttons seems to me a good thing to.)
Just my 2 cent thoughts on this.
I think I am in agreement with most of the suggestions.
"1) On Mouse Down: Do nothing. The current P/E/F if there is one should already be highlighted.
2B) On Mouse Up: If the mouse hasn't moved, Clear-and-Select, Deselect-One or Add-Select, depending on the button."
I would also question the 2A in relation to current standard.
As it currently stands (unless something changed and I have yet to notice) I can select a P/E/F and then click anywhere else and drag and the selected P/E/F will move.
the rest 1, 2B I agree with, if click on a new P/E/F then others should be de-selected and new one selected (or added to if ctrl-click)
but 2A means that you would have to keep clicking the P/E/F ... actually scrub that.... I think Im ok with it, but I do in fact now have another problem caused by this.
(Unable to modify Selection of P/E/F's)
ok, So, lets say you have n P/E/F's selected and you want to move all of them.
Do you:
just click and drag
Ctrl-Click and drag?
I ask because it seems that to simply click and drag would un-select all other P/E/F's and only move the 1... this is bad.
"and also does a "Headlight" effect, where the only light source is from the camera, thus illuminating the mesh no matter the viewing angle. This is my favorite in other modeling programs, and an extremely helpful aid to modeling."
Can I ask if you mean flat shading?
Set Ambiant to 1.2 and diffuse to 0.001 and click the combine button (=). is this the same effect?
(this flat shading is how I model for GF since the GE engine does not do lighting)
(Also of note, the reason for 0.001 is so that it keeps the texture assigned, if set to 0, the texture is removed)
Trev
Remember, this is for fast select ie tweaking. It's primarily for rapid movement of individual elements along the screen space. 99% of the time, you won't have an active selection to work with, nor would you build up a careful selection using the tool--that's for the normal selection tools in non-fast select mode. Clicking in an empty space to deselect while in tweak mode is both natural and helpful--I've experienced this myself in another modeling program (XSI Mod Tool) and use it quite often.
Traditionally, shift and ctrl are used for adding and removing from the selection. Myself, I've always liked Anim8or's three-button selection method and it's easy to remember which does what. A lot of times in other programs, I mix up what shift and control do--that's not the case with Anim8or because it's unique.
but 2A means that you would have to keep clicking the P/E/F[/s] ... actually scrub that.... I think Im ok with it, but I do in fact now have another problem caused by this.
Hello Trevor, again I'll remind you that this is Fast Select we're talking about, as I mentioned to MvGulik. Fast Select is a tweaking tool, primarily something you use to rapidly move stuff around piece by piece in an intuitive manner. It's not a replacement to normal mode, which is used for more careful, precise editing. To be exact, Fast Select is a combination of the selection tools and whatever transformation tool it is--you single click to modify the selection if you really have to, you click drag to transform it. Not sure what build you're using, but if you're in Fast Select mode and have a selection, and left-click and drag in an empty space, it deselects everything (because it's using the mouse button select functionality). If you right-click and drag in an empty space, it drags the current selection. It's weird. Don't get me started on middle-clicking and dragging lol.
This is also why I want MMB to use the transform-along-normal functionality instead of the Ctrl button. This way the Ctrl modifier key can be used for painting the selection when clicking and dragging across whatever it is you want to paint a selection, and therefore be consistent with the original selection tools while mitigating a faster editing process.
Do you:
just click and drag
I think you misinterpreted the actions Steve suggested. In Fast-Select, click dragging on a selection moves all selected elements. Click-dragging off a selection doesn't move the selected elements, and newly selects and moves an element if it's on it, or otherwise deselects. So to answer your question, you click on the selection and drag.
Trev
Nope, not flat shading. Flat shading is a horrible aid for modeling, you can't see contours at all. Look at the video I made of Headlight view and a good shading for modeling, which allows you to edit at any angle without having to fight the lighting:
Not really the best video :P The light source seems to be an infinite one, rotated slightly down at an angle relative to the camera. It's hard to tell with the video, but if you rotated to, say, the underside of the squirrel's chin or inside the mouth, it'd be illuminated from that angle still.
Are you planning to add any modelling tools? I'm especially interested in edge dissolve and edge collapse, and I'm sure others are, too.
I think that should be left in; but however I still propose a fix to it.
I think that there should be an undo selection and redo selection added to the undo redo list. In other words if you accidentally unclick all the faces you specifically selected, then you could easily hit undo deselect. And if you wanted to take it further you could have it as a separate undo function like shift-ctr-z instead of normal ctr-z (and you could access it from the menus as well in a similar fashion).
nemyax: I'm considering new modeling tools but want to finish all the UI changes that I'm working on now and get an official release out. New modeling tools certainly might include edge dissolve, edge/face collapse, and Raxx's idea on an improved cut tool.
Is there a link to the description?
[Added by Steve]: Here's a link: Topo Tool (http://www.anim8or.com/smf/index.php/topic,5087.0.html)
[/youtube]
Has anyone else noticed problems trying to select vertices on subdivision models with smooth shading enabled? I find it works in wireframe mode but not smooth shading.
I'm also finding the non-uniform scale tool to be a bit erratic when only selecting vertices, particularly when trying to bind it to a specific axis. I'm finding that it sometimes works, sometimes doesn't, and is consistently ignoring the xyz axis buttons.
Why does a topographical (?) knife sound like turning off back faces and then just cutting and hitting each previous vertex before cutting the next line?
It's is pretty weird using it with the mirror
It isn't. And the mirror should work reliably regardless of what you use.
I mean that new(ish) live mirroring tool in Anim8or. I think mostly in that if you cut two lines to points that lie directly on a axis, the points automatically get joined. Maybe that's not weird for you, but to me it is.
davdud101: Can you show me what happens now and what you'd like it to do?
Well, I think it may be a more of a me thing... I just need to learn how to use the tool better. It works just like it should, when I look at it in the scope of things.
I think sometimes its that you can join faces and make somewhat strange edits *across the axis.
I take it someone else likes stingray. Kinda spammy though without a comment and the fact its in completly the wrong topic.
New ideas look good, just seen the split topic and it looks interesting.
Trev
HI trev..the forum offers ie provides for this form of communication... perhaps i was being too subtle, too modern, too connected to the zeitgeist ,i do stop short of non sequitur humour/communication a big favourite of mine as intellectually i know not everyone is on the same plane....hey but as the man says...ANYTHING can happen in the next half hour.
"This is the Voice of the Mysterons ...... Earthmen, We need to have some progress with Scene mode started as soon as possible ."
"Unless you do so in the next half hour Our Agent Captain Black will take steps"
"You have been warned Earthmen"
Ah, I understand now.
It would have been better had you only posted the required segments though. Posting the whole intro just looks like spam.
Hehe, nice use of mysterons.
Trev
I always thought Mysterons was a Portishead song, but what do you know.
OK enough spam :-)
