General Category => General Anim8or Forum => Topic started by: Darknessspliter on October 25, 2014, 09:59:16 am
Title: Sequence rotation.
Post by: Darknessspliter on October 25, 2014, 09:59:16 am
Hello guys.I have a problem with the rotation directions in sequence.I have 2 same directions and one different for hand instead of 3 different .Can you tell me how to fix it,please?
(http://s28.postimg.org/9b2qc0dhp/walk.png)
Title: Re: Sequence rotation.
Post by: Raxx on October 25, 2014, 12:37:33 pm
As far as I can tell, that's just how it ended up after rotating along the Z-axis. I'm guessing your figure has the arms straight out to the sides in a T-fashion, and in the sequence editor you rotated them down 90 degrees. You need to go back to your figure and rotate that upper arm bone 90 degrees on the Y-axis (right-click and drag). This way you'll get the range of motion you want in the sequence editor.
