Artwork => Finished Works and Works in Progress => Topic started by: ronaldefarmer on July 08, 2014, 01:18:41 pm
Beacon Towers: Experimenting with lights and shadows--feel free to comment.
I read the title as bacon towers, now I'm hungry.
The only two things I have complaints about is the shadows aren't scattered when further away (soft) and also the horizontal beams supporting the tower (supposed to be metal or wood?) are thicker than the vertical ones.
Besides that it looks good.
the lamps are the same size as the horses - i doubt you'd ever get a single bulb that big, so i'd suggest adding a bit of framing around them, to make it look more like a composite bulb-and-lenses structure. maybe also de-saturate the colour of the grass, as colours don't tend to show that bold in low-light conditions. just nitpicking though - i think generally the image works well =]
Cooldude234: I corrected the crossbeams in the towers a bit and tried to soften the shadows. I still don't like the shadows.
I think they would be, if it were a lighthouse or a Bonfire!
I defiantly think the cross beams look better now.
Still want that bacon though. Maybe one of those horses could suffice ;)
if it was a bonfire, then it could easily be that big - i've seen bonfires a lot bigger than that! 8) but the yellowy oval shapes in the renders look more electric-bulb-ish than bonfire-ish. a lighthouse would need a very large bulb, yes, but the size of a horse? i just don't think that'd be feasible to build/transport/install/etc - much more likely, you'd have a bulb the size of a football or thereabouts, possibly with a horse-sized lens mechanism surrounding it. that's what they'd done at the last actual lighthouse i climbed up...
I was thinking that the light sources would be some sort of supernatural devices rather than modern light bulbs or simple flames, maybe a bit like that eye on Lord of the Rings. I have a somewhat better render that I will post later.
What about this one? Elements are rearranged, shadows are softer, light source looks a bit different. I meant to desaturate the terrain a bit, but I don't see a difference really.
i think the new light source works well =]
