General Category => General Anim8or Forum => Topic started by: SValera on April 11, 2011, 03:01:09 pm
What is map transparency as its make and use
I think you mean a transparency map. This is a black and white image you can add to your material. The black parts of the image will be transparent in your render, while the white will be visible. With such a map you can easily make objects which are hard and time-consuming to model: like leaves, grids, hair etc
Read more about the use here: Advanced textures (http://anim8or.com/manual/10_materials.html#advanced_textures)
