Don't Forget
A tribute to Anim8or and its Community
This is a collaboration from all the members of the community that wanted to do something memorable. The first step is to see who's involved in this. At least 10 contributors are needed for us to pull it off successfully, so I hope you're interested! Just reply to this post if you wish to be involved.
The Idea
Basically it'd play the Don't Forget song by Demi Lovato. Kind of a sentimental animated montage thing from the users here.
Granted there aren't a whole lot of us anymore, but I know there're a lot of lurkers that still log in and browse around.
Assuming we have at least 10 people:
1. The contributor makes their own avatar of themselves in the form of a person, creature, robot, whatever entity they think best represents themselves, and has them dance, stand, play around, do whatever within a certain timeframe. Maybe each contributor should have the robin in there in some shape or form.
2. Each contributor makes a 10 second clip and a 2 second clip.
3. Each contributor's clip is played one after the other in sequence. The 10 second clips are played first, then some sort of tribute to Anim8or is done in a title screen, and then the 2 second clips are played afterwards. Each 10 second clip has their username and real-life photo that fade in and out along the bottom.
4. The positioning and fading of the names and photos will be done via post processing, so the contributor doesn't have to worry about that part of it (aside from providing the photo).
5. The scene can have whatever environment the contributor wants. Whether it interacts with their avatar or is static or even nonexistant.
6. Each contributor renders their own clip. To keep it all consistent, the settings will be predetermined. More than likely 1280x720, bicubic AA, and H.264/MPEG-4 codec with very low compression. Then each contributor can upload it to one of my websites and I'll combine them all together, add the names and photos, transitions, title screens, etc, and upload it to Youtube and Vimeo.
7. Anim8or will be the only program used for modeling, animation, and rendering, since this is a tribute to Anim8or. Yeah it's a pain to the guys who found other software to make it easier in certain areas, but that's what'll make it special.
8. Use whatever you want. Add stuff you've already made or make all-new stuff. It's your clip and yours alone.
NOTE: Depending on the number of contributors that sign up, the actual length of the clips will be determined.
This is the song that would be playing during the duration of the animation:
Video Settings
Resolution: 1280x720
Framerate: 30
Encoding: H.264/MPEG-4 (high bitrate/settings)
Format: AVI
Encoding Your Video
Download and Install:
XVid 1.3.1 (http://www.koepi.info/Xvid-1.3.1-20110324.exe)
Virtualdub (http://virtualdub.sourceforge.net/) Install only the 32-bit one!
For Image Sequences:
Open VirtualDub
Go to File->Open Video File...
Navigate to the folder containing your images rendered from Anim8or
Select the first one and select Open
All the images in that sequence should now have been imported
Go to File->Save as AVI...
Save the AVI file into a separate folder uncompressed
Continue on to your next Image Sequence and repeat the steps above
After all your image sequences have been saved, continue with the steps below.
For Video Files:
Open VirtualDub
Navigate to the folder containing your first video file
Select the video file and press Open to load it into the program
If you have more than one video clip you need to put together:
Go to File->Append AVI Segment
Select the next video file that needs to be added to the end of your project.
Keep performing that step until all your clips are imported.
To Encode It To H.264:
Install the XVid codec if you haven't already.
In Virtualdub with your project Open, go to Video->Compression...
In the list of codecs, select "Xvid MPEG-4 Codec" and press Configure
Set "Profile @ Level" to Highdef
Click on "Target Quantizer" (if "Target Bitrate" isn't there"), and set it to the highest bitrate (9708 kbps)
Click on the "more..." button next to Quality Preset.
In the options that come up, set Motion search precision to "6 - Ultra High" and VHQ mode to "4 - Wide Search"
Leave all the other settings as they were and OK out until you're back in Virtualdub
Go to File->Save as AVI and save it as an avi file
A progress window will pop up as it's processing the video.
And that's it! If you see any major blurring or artifacts, then chances are you'd have to tweak the settings a bit. Don't reduce the bitrate or quality settings if possible though!
Participants
CoriDavis
3Dgeek11
NickE
captaindrewi
Kreator
lynn22
Janro
Headwax
Bugtrooper
Anyone else?
