General Category => General Anim8or Forum => Topic started by: blazecon0 on May 25, 2010, 01:03:25 pm
i got a wierd problem. im making an animation of a plane crash using morph targets, but i made the plane out of many different parts, so in order to morph them the way i want to i group them together, but when i try to use modifiers my model disapears when i bind them, if i try to effect the modifier, it says its not bound to a object. this dosnt happen when i dont group them but not everything moves together.
modifier i think is only meant for binding to solids or mesh state shapes
i have only used modifier once making slinky spring bend
what you can to do for it to work is instead of group use join solids this will also reset pre existing morph targets ! but as all parts will be together as single scene element it should make no difference
if you need to re-separate the model parts in point edit change selection to faces and select by connected or select by material and de attach faces ! it think this also reset morph targets
alternative is once you got modifier how you want it work copy paste the modifier for each and every mesh binding separately !
i like that last idea :D
thx
