General Category => General Anim8or Forum => Topic started by: yi239 on May 14, 2010, 10:25:00 pm
I have the shape of a torso. the edes look real sharp, but i want to make them wider, but instead of a point id like them to be
Rounded....How would i do that? ???
Well one method you could do is convert it to subdivide by going build>convert to subdivide, the same way you convert a base object to a mesh, it will give the object a rounded shape but in the point editor it will keep its blocky look to make it easier to edit it and continue work on it.
do i subdivide the edges, faces, or vertexes?
there is convert to subdivided and subdivide faces. what you want to do is convert to subdivided.
google.com nurbs. im pretty sure thats what converting to subdivided is.
Select the mesh object and go "Build>Convert to subdivided" and you can double click and change the subdivision level.
How would i take one point, and turn it into two points? or a shape more points?
any tips for making a person look muscley/Designing muscles? Maybe making a person look more natural?
Ty for all your help.
