General Category => General Anim8or Forum => Topic started by: yerren on March 07, 2008, 10:31:45 am
hey ;)
i will made a movie and i now how to do this mare how insert i more objects in a scene?
thanks
thanks yerren
go to build --> add object --> click on the object you want, now move it around in the scene however you want
i hope that helps
yea i now that mare i mean that i have 2 object's in a scene ;)
anybody i need this hard ;)
Just do it again. It may place the two objects in the same position, so you'll have to move the first object to see the second. But just go "build>add object" again.
Mare are always object 01 and never object 00 and i wil 2 diffirendt objects in a scene ;)
plz i need it so much ;)
You DO know that you can have multiple objects in the Object Editor, right? If you have more than one object, it's wise to actually NAME each object. For instance, in Object Editor mode, select an object (click on Object tab and scroll down to the desired object). Then, click Settings > Object... THis will open the Object Editor dialog box, where you can type in an appropriate name for the object (ball, box, couch, person1, person2, whatever).
Then, in the Scene Editor, you can "build" your objects, one-by-one into your scene. If you want TWO or more of the same object, realize that Anim8or will place each at the SAME LOCATION, unless you move one one (or more) after placing it into the scene.
Then, even though you may have placed more than one of the same object in the scene, Anim8or will give each a new NAME in the scene. For instance, let's assume you have an object that you've named "BALL" in the object editor. You can place two or more of this BALL object into a scene, and Anim8or will give it a new name (starting with "eobject01," then "eobject02," etc.).
Hope this helps. By the way, from the posts you've written, it seems that you REALLY need to read the Anim8or manual, and DO the tutorials!
can it in dutch i can not so good english ;)
wait i have it all thanks for your help ;)
I used babelfish to translate. Sorry if it's still hard to understand:
U weet dat u veelvoudige voorwerpen in de Redacteur van Objecten kunt hebben, recht? Als u meer dan één voorwerp hebt, is het wijs elk voorwerp eigenlijk om TE NOEMEN. , Op de wijze van de Redacteur van Objecten, selecteer bijvoorbeeld een voorwerp (klik op het lusje en de rol van Objecten neer aan het gewenste voorwerp). Dan, klik het Voorwerp van Montages... THis zullen de de dialoogdoos van de Redacteur van Objecten openen, waar u in een aangewezen naam voor het voorwerp (bal, doos, laag, person1, person2, wat) kunt typen.
Dan, in de Redacteur van de Scène, kunt u uw voorwerpen, één-door- in uw scène "bouwen". Als u TWEE of meer van het zelfde voorwerp wilt, realiseer dat Anim8or elk bij de ZELFDE PLAATS zal plaatsen, tenzij u één één (of meer) na het plaatsen van het in de scène beweegt.
Dan, alhoewel u meer dan één van het zelfde voorwerp in de scène kunt geplaatst hebben, zal Anim8or elk een nieuwe NAAM in de scène geven. Bijvoorbeeld, veronderstel u een voorwerp hebt dat u "BAL" in de objecten redacteur hebt genoemd. U kunt twee of meer van dit voorwerp van BAL in een scène plaatsen, en Anim8or zal het een nieuwe naam geven (om te beginnen met "eobject01," toen "eobject02," enz.).
Hoop dit helpt. Door de manier, van de posten u hebt geschreven, schijnt het dat u WERKELIJK het Anim8or- handboek moet lezen, en de leerprogramma's DOEN!
zal ik doen ;)
