General Category => General Anim8or Forum => Topic started by: MeepII on March 16, 2010, 11:30:17 am
When I run scripts, it comes up with some code, says its found some errors and the whole program closes. I've tried it with several scripts and several computers, but nothing seems to work. Does anyone know how to fix this?
I think you will have to provide more information. For example, which script exactly did you try to run? What exactly did you do before Anim8or crashed? What error messages did you get? What kind of project was open at the moment? The more information you provide, the better the chance that you will get help.
I used the mesh2mesh script,on version 0.95. It was a high poly leopard. There were no error messages
try anim8or preview version v97 issue mite be because script use functions not supported in v95 !
...it comes up with some code, says its found some errors and the whole program closes...
...There were no error messages
Huh?
Like Bob_I_Ts said, it might be caused by an old version of Anim8or. If that is not the case, you will really have to provide more information (what about a screenshot?)
Oh, sorry.
It comes up with the lines of code, which, at the end, say it's found problems in line X
...say it's found problems in line X
If this is all the information you can provide, the only thing I can say is "sorry, I can't help you..."
I'm getting tired of this...
Ok, let's try once more: What exactly was the error message in the output window? What was the line number? What about posting a screenshot?
btw. I bet the problem is an old version of Anim8or (like Bob_I_Ts said...). Try downloading v0.97 preview...
No,I know it is that it is because it is an old version now.
It's hardto take a screenshot because it closes immediately.
I have one question about script console. When running any script it appears, but when i want to close it, it close the whole program. Can i close only the console or i have to go on with the console staying open even if i whould not use it for rest of the project?
The console will have to stay open. But you can choose to turn it of so it wont open when you start up anim8or: go file>configure and uncheck Script Console.
Ok, that's what I thought :). And yes, I had done the config part 8). Thank you
