General Category => ASL Scripts => Topic started by: rellik420 on February 25, 2010, 02:47:33 pm
Title: convert to sub then back to mesh
Post by: rellik420 on February 25, 2010, 02:47:33 pm
the way i model is when its a mesh at 180. the final is almost always converted to mesh. i always convert to mesh to see what it looks like then tweak it a bit the convert it back to mesh. (i double click the object make the subdivisions 0-0 (which puts it to default 0-1 or 1-2 i think) then i convert to mesh, double click on the object and set it to 180)
hopefully i explained my process. it eats up a bit of time as well.
my question is: can you make a script to use hot keys or buttons to do just that? i would just model when its sundivided but it gets really hard to see and some points r hidden under the mesh.
Title: Re: convert to sub then back to mesh
Post by: BOB_I_Ts on March 13, 2010, 12:48:31 am
Kubajzz has a script in the script database topic here unsub.zip (http://an8.the-meadow.net/Com/ASLTopic/unsub.zip) does that help ?
Post by: hihosilver on March 13, 2010, 02:33:48 am
Sadly no, there are no hotkeys that can change levels of subdivision or hotkeys to converto mesh/subdivision objects (or turn up the smooth level.)  You'll just have to continue the way you're doing it! Sorry, but scripts just don't allow for it currently from what I know.
