		General Category => ASL Scripts => Topic started by: Kubajzz on January 11, 2010, 01:49:45 pm
				Yet another potentially useless little plugin...
 This is where the idea came from: http://www.anim8or.com/smf/index.php?topic=2934.0 (http://www.anim8or.com/smf/index.php?topic=2934.0)
 If you need to duplicate a part of your mesh, select several faces and run this plugin. It does basically the same like the Detach Faces command, but it does not change the original shape.
 Download link (http://an8.the-meadow.net/Com/ASLTopic/CopyFaces.zip)
				hi Kubajzz
 Very cool script (as always)!!
 PS:  after  i send to you a other ideia of script "points controller"
 to facilitate morph animations..OK..
 i send after ok
 thanks!!
				hi Kubajzz, :D
 please see my post..
 http://www.anim8or.com/smf/index.php?topic=2943.msg21385#msg21385
 is possible make this?!
 thanks
 Neirao-Brazil
