General Category => General Anim8or Forum => Topic started by: Gamemaner1234 on December 09, 2009, 02:52:10 pm
I use anim8or frequently and am working on a project. I recently wiped my hard drive but the folder that contained everything I have related to anim8or. Here's the glitch. It didnt happen before I wiped my pc, but now when I set an object to use a texture(That isnt just a color) it shows up on the 3d view, but doesnt show up on the little sphere in the textures drop down like it used to. And when I render the actual image, it doesnt show the textures either, the walls are completely blank. What made this happen? I saved EVERYTHING and yet anim8or is giving me this problem. I reinstalled the same exact drivers I used to have and everything.
it might be ur GUI settings. u might wanna look at that.
Get a load of these images, the top one is the one I rendered OF the display on the bottom. And the grey textures are the stone floor, and brick walls you see. Stange bug eh?
And I looked at the Configure GUI thing, it doesnt have anything in it that would help. File>Configure GUI right?
try going to View>preferences and looking in there. there's 2 checkboxes for textures, one for the viewports, and one for the output
also check to make sure you still have your video card drivers.
V got here first V
Click View > Preferences, and make sure "Textures" and "AntiAliased" are checked in the File Output section.
YESS!!!! Thank you! Thank you! Thank you! Thank you!Thank you! Thank you!Thank you! Thank you!Thank you! Thank you!
I've been obsessing over this all day. Thanks guys. :)
i go through this every time i change computers.frustrating, i saw your question and knew i should have known the answer, but i couldnt remember. ill probable have to ask again someday.
