Artwork => Finished Works and Works in Progress => Topic started by: neodelito on August 22, 2009, 06:12:13 pm
testing 3d view of a olds models in flash
Edit..
You have reaso i need make a mask more small...
http://www.modulosoporte.com/soporte/page.php?14 (http://www.modulosoporte.com/soporte/page.php?14)
Umm. It looks a bit pixelatted. I think it's the white edges around the models. The first one you can see the ring threw the model. Don't know if you were trying to do that. You should try rendering the video at a higher res. and using a alpha channel.
yep.. the swf expand to fullscren .. the real size is 250x250, is for upload model to my website and show them in all angles....
Well the models would look better without the white edges. You need to grab them with a smaller mask.
