General Category => General Anim8or Forum => Topic started by: sloGGan on August 07, 2009, 10:27:40 am
Title: I need some help
Post by: sloGGan on August 07, 2009, 10:27:40 am
Please can anyone tell me how to make FIGURE and how to MULTI BONE SKIN object.
When I click sequence and when I import Figure show one message... . How to transport from figure to sequence and from sequence to scene
I try 100 time but I can not do this, please please help!
Title: Re: I need some help
Post by: lynn22 on August 07, 2009, 12:43:40 pm
Take a look at these tutorials for multiple bone skeleton (http://www.3d-anim8.com/tutorials/tutorial.asp), skinning, sequence building and rendering your animation.
Post by: sloGGan on August 07, 2009, 02:13:04 pm
Thank you very much
Post by: sloGGan on August 07, 2009, 06:39:12 pm
But I can not move the object, I select object and I can't move!!!!
(http://img200.imageshack.us/img200/3834/problemrgz.png)
Please help!
Post by: lynn22 on August 07, 2009, 06:43:10 pm
You're most welcome ;D
Post by: johnar on August 08, 2009, 01:58:43 am
 You're still in figure mode. You need to have your figure in sequence mode or scene mode before you can move it.  ;)
Post by: sloGGan on August 09, 2009, 01:34:57 pm
But I can't move the figure in seuence mode. Can you or other make one tutorial how to do this?
I select secuence mode but i can not move please help, how to do this?
Post by: Mreenav D on August 09, 2009, 01:49:44 pm
In figure mode make sure that all the joints in their respective bones are there correctly.to ensure this double click on the required bone and set the correct axises of movement.Then go to sequence mode and select the required bone. Then click on the rotate bone tool and move it.You will be able to move the bone only in the direction which you have set in the figure mode .Hope that helps.
Post by: kreator on August 09, 2009, 01:55:49 pm
Check my Video Tutorial at ...
http://www.dotan8.com/TUTORIALS/Bones & Skinning.wmv (http://www.dotan8.com/TUTORIALS/Bones & Skinning.wmv)
Loads more at www.dotan8.com.
Post by: lynn22 on August 09, 2009, 02:34:37 pm
To move a bone in sequence mode you first have to click on the "key" button - last button on the right side - when it turns green you can select a bone and move it and the movement will be recorded.
Post by: sloGGan on August 10, 2009, 11:11:28 am
How to thank you? Thanks very very much!
Post by: kreator on August 10, 2009, 01:59:56 pm
Pleasure sloGGan, There are many more at Dotan8.
 I am producing these videos to help all anim8or beginners , much better to see someone actually doing it,  and, in a good format, rather than some obscure Youtube thingy.
I hate looking at them with no idea of what is happening because they don`t actually tell you or stick some music track in!!
Post by: sloGGan on August 10, 2009, 06:51:39 pm
Thanks, kreator
Post by: sloGGan on August 10, 2009, 07:39:18 pm
How to make shadow, I can not open tutorial from www.anim8or.com (page don't found)
Can anyone help me how to do shadows?
Post by: RudySchneider on August 10, 2009, 07:59:55 pm
sloGGan --- You really should read the manual!  It can answer SO MANY of your basic questions.  For instance: http://www.anim8or.com/manual/7_scene_editor.html#shadows
Post by: headwax on August 10, 2009, 09:05:51 pm
:)    what rudy means is that in scene mode
you have to add a light then click it and a window opens up and  you go to the advanced tab and click that
and then make sure shadows is ticked and then make sure that you tick ray traced as the manual probably doesn't tell you that the other shadows are buggy
and then close that window and insert an object via The Build menu (hey you use tghis menu to put a light in too :) )
then  double click the object or use the drop down Settings menu and change the elemments settings (our element being the object)
and make sure that casts and recives are checked in the window then close that window and do a  render.
via  Render>Render image
show us what you render
easypeasy 'cept when you are starting and it's all really  confusing?
Post by: RudySchneider on August 10, 2009, 09:35:57 pm
What headwax said...
And reading the manual will still answer a lot of questions.  Heck, it still comes in handy for those of us who've used Anim8or for a long time!
Post by: sloGGan on August 11, 2009, 10:32:52 am
i need one video (tutorial) to learn how to do this!
Can anyone give me one video how to do this?
Post by: kreator on August 11, 2009, 05:49:58 pm
here u go....http://www.dotan8.com/TUTORIALS/Lights.wmv
any more requests email or PM me either here or at www.animanon.com
Post by: sloGGan on August 12, 2009, 08:30:52 am
thanks for tutorial!, you help me so much with this and other tutorials, thanks!
