General Category => General Anim8or Forum => Topic started by: drayeon on July 12, 2009, 05:07:01 am
I am designing a model of a car. I wanted to design one with a model of an engine that could be seen if I ever wanted the hood up but, I wasnt that good yet and just designed the body of the car first. I was not aware that I could just hide the car and design the engine. So I designed the engine in a seperate anim8or file.
My question is can I load up the engine into the same object/edit mode are as the car I designed or will I just have to remake the engine?
To solve your problem, import your engine file into your car file (object>import)
then select ALL of your engine and Copy
go to your car object and Paste your engine, that's it ;)
Thank you for the help. Forgot about copy and paste.
