General Category => General Anim8or Forum => Topic started by: personak on June 25, 2009, 06:37:53 pm
Title: Trees
Post by: personak on June 25, 2009, 06:37:53 pm
I can't figure out how to create a tree - any help would be great.
Title: Re: Trees
Post by: dwsel on June 25, 2009, 07:31:02 pm
Making tree by hand is usually time consuming task. From your question I assume you just want to use a tree as a part of project so creating procedural tree will be much faster. You can try then procedural tree generators like:
http://www.treegenerator.com/download.htm
http://arbaro.sourceforge.net/
http://ngplant.sourceforge.net/#downloadanc
http://www.frecle.net/forum/viewtopic.php?t=780
http://dryad.stanford.edu/
http://graphics.uni-konstanz.de/~luft/ivy_generator/
Some of generated trees will need conversion to *.obj file to be opened in Anim8tor.
Title: Re: Trees
Post by: personak on June 25, 2009, 07:32:34 pm
thanks, im checking it out
Title: Re: Trees
Post by: mak on June 25, 2009, 11:54:01 pm
theyer not realy that hard. just kinda vary off the eggplant tut. leaves can be tricky but you can allways cheat with texturs
