General Category => General Anim8or Forum => Topic started by: matt the brat on June 16, 2009, 08:40:05 pm
Title: how to add peices to bones?
Post by: matt the brat on June 16, 2009, 08:40:05 pm
alright i'm making a master chief guy, and i'm very new and don't know how to animate anything yet, but i need to know how to set certain objects such as a foot and connect it to a bone, when i highlight a certain peice like a  bicep, i go to settings>object>and i type in the name, now when i go to the figure to make a skeleton, and highlight a bone, then press build>add object> then ok the object name, then the whole halo body appears. shouldn't only that bicep appear? the tutorial isn't very clear. ??? sry if i'm noob.  :-\
Title: Re: how to add peices to bones?
Post by: johnar on June 16, 2009, 10:01:59 pm
 The bicep needs to be a seperate object.
 When adding eg: object 1 to a bone, everything labelled as that object will be imported to figure.
 Select bicep -> cut -> go object -> new -> paste.
 Now name the bicep. ie: right bicep
 Now, in figure mode, select R bicep bone -> add object. Choose new object named right bicep.
 Hope that helps
Post by: matt the brat on June 16, 2009, 11:02:07 pm
well how would you keep it to size then? how do you know if its all proportional?
Post by: hihosilver on June 17, 2009, 12:06:05 am
You can make it all as one object at first, then cut/paste the different parts into new objects.  When you cut/paste the size will not change so everything will be proportional.
Post by: matt the brat on June 17, 2009, 12:44:48 am
alright thanks, i'll try that out. really appreciate your guys' patience with a noob lol
Post by: rellik420 on June 18, 2009, 03:13:50 pm
is there a better method? having seperate objects opposed to one solid object?
Post by: matt the brat on June 18, 2009, 06:09:03 pm
i don't know but when i copy a peice of my guy, and make a new object then paste, the color is washed away from it? whats up with that?
Post by: johnar on June 21, 2009, 12:19:36 am
rellik420:
 Yes, you can add one solid object.
 If you have a character that is 1 object, add him to a bone 1 above the root bone. (in most cases).
 Then you'll need to 'skin' your character. Each bone will affect each part of your model, depending how you skin it.
 (search tuts/information 'Rigging and Skinning)
 matt the brat:
 Washed out colour. Most likley is in your material settings. Actually, the naming of your materials.
 The matertial on your  original object is probably still named 'Material01. Thats the default name. So when you copy part of it to a new object, you also copy the material name. ie: material01.
  Changing the name to something b4 copying should fix this.
 Basically, always name your materials, so they dont get mixt up when moving the objects around
Post by: matt the brat on June 21, 2009, 07:13:19 pm
i alrready name them like "sage" or "visor" but i guess i forgot to import them lol
