Artwork => Finished Works and Works in Progress => Topic started by: Ratticis on April 26, 2009, 08:34:19 pm
My first attempt at modeling
(http://i5.photobucket.com/albums/y151/Ratticis/5Window.jpg)
That's really good, you got the hang of it :)
Very good for a first try. I would make it a tad wider ;)
Put some few details into it and render it using Art.
Thanks for the feedback. I was going to keep going and add some more detail, but I decided that I would probably be better off to start over using what I had learned on this one to create something better. It probably took me about 2-3 hours but I really learned a lot and could probably do it again in about 20 mins :P
Learning by trying is the real trick in this program... This is a good little "first ever" model.
I know that every time I start something I learn some new technique just by experimenting, and then end up many times starting over and making something a little better than the previous attempt.
I look forward to seeing your rework, because I think it'd be cool to compare it with the first, and make for a more meaningful display of "see what I learned?"
(http://i5.photobucket.com/albums/y151/Ratticis/5Window-2.jpg)
Well, the roads looking more defined now from the rest of the land, although I'd suggest you scale down the texture or using a higher quality texture, this will get rid of the pixilation for you.
But, this is very good for a first model!
Ya, I just took 4 seconds yesterday (Plus the 10 minutes waiting for it to render :P) and changed the material on the wheels and rad support to chrome and re-rendered it using ART
