General Category => ASL Scripts => Topic started by: Claude on April 04, 2009, 08:10:59 pm
Lets say you want to add a side to a few faces.
You have to store all the data of these faces:point indexes,material
indexes, etc, then delete the faces and finally recreate them.
The problem is that if you delete the last face using a material,
Anim8or removes the material from the material list.
The faces are all created,but some end up transparent
since their material index points at a non existing material.
Would it be possible to let the responsability of cleaning up to the
script using the RemoveUnusedMaterials(void)
or the RemoveUnusedData(void) function ?
Thanks
P.S.
Small detail,the spec says:
"OpenFace() begins the definition of a new face. It returns the index of the newly created face. If an error occurs it returns 0 and no new face is added. "
It seems problematic that the error returns a valid index value 0 .
To continue working on the script,I added materials to other faces and
selected a point that wouldn't force Anim8or to delete a material from
the material list.It worked,but something else showed up.
Here's the face description before the script is run:
The faces marked with a X are deleted by the script.
faces {
4 4 1 -1 ( (0 0) (4 4) (6 6) (2 2) )
4 4 1 -1 ( (1 1) (3 3) (7 7) (5 5) ) X
4 4 2 -1 ( (0 0) (2 2) (3 3) (1 1) )
4 4 2 -1 ( (4 4) (5 5) (7 7) (6 6) ) X
4 4 3 -1 ( (2 2) (6 6) (7 7) (3 3) ) X
4 4 3 -1 ( (0 0) (1 1) (5 5) (4 4) )
As expected,the undeleted faces become the first 3 faces.
The point and texture index are correct,but the face material
index are modified for no reason.
The recreated faces are correct except that one doesn't show
up.
faces {
4 4 0 -1 ( (0 0) (4 4) (6 6) (2 2) )
4 4 1 -1 ( (0 0) (2 2) (3 3) (1 1) )
4 4 2 -1 ( (0 0) (1 1) (5 5) (4 4) )
4 0 1 -1 ( (1) (3) (8) (5) )
4 0 2 -1 ( (4) (5) (9) (6) )
4 0 3 -1 ( (2) (6) (10) (3) )
Attached are the complete files.
Hope it helps.
Bye
