(https://anim8or.com/resources/asl/assets/PI.gif) Download (https://anim8or.com/resources/asl/assets/PI.zip) | 3D PI Chart Create any sized chunk of cylinder similar to a pie based on Divisions, Radius, Texture Scale, Start Angle, End Angle, and Depth. Author: BOB_I_Ts (http://www.anim8or.com/smf/index.php?action=profile;u=62) [Website (http://homepage.ntlworld.com/w.watson3/)] Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=15.0) |
(https://anim8or.com/resources/asl/assets/4wall.gif) Download (https://anim8or.com/resources/asl/assets/4wall.zip) | 4 Wall Basic frame shape that allows you to create a square-shaped "hole in the wall". You can adjust the Horizonal Scale, Vertical Scale, Depth, and the hole's offsets and sizes. Author: BOB_I_Ts (http://www.anim8or.com/smf/index.php?action=profile;u=62) [Website (http://homepage.ntlworld.com/w.watson3/)] Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=15.0) |
(https://anim8or.com/resources/asl/assets/advancedplane.gif) Download (https://anim8or.com/resources/asl/assets/advancedplane.zip) | Advanced Plane Creates a simple rectangular plane. You can change the width, height and the number of divisions. Author: Vobla (http://www.anim8or.com/smf/index.php?action=profile;u=160) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=131.0) |
(https://anim8or.com/resources/asl/assets/archway.gif) Download (https://anim8or.com/resources/asl/assets/archway.zip) | Archway Creates an archway block. You may define the width, height, length, divisions, ceiling depth, and angle. Author: BOB_I_Ts (http://www.anim8or.com/smf/index.php?action=profile;u=62) [Website (http://homepage.ntlworld.com/w.watson3/)] Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=15.0) |
(https://anim8or.com/resources/asl/assets/cage.gif) Download (https://anim8or.com/resources/asl/assets/cage.zip) | Cage Create a variety of cage shapes. You may specify the XYZ Size and Divisions, the thickness of the wire, and if it needs to be a single wall or a full cubic cage. Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=697.0) |
(https://anim8or.com/resources/asl/assets/cog.gif) Download (https://anim8or.com/resources/asl/assets/cog.zip) | Cog Cog Wheel shape. Many different parameters make for a large variety of cog wheels available. Author: BOB_I_Ts (http://www.anim8or.com/smf/index.php?action=profile;u=62) [Website (http://homepage.ntlworld.com/w.watson3/)] Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=15.0) |
(https://anim8or.com/resources/asl/assets/diamond.gif) Download (https://anim8or.com/resources/asl/assets/diamond.zip) | Diamond Make diamonds of any shape and size with this plugin. You can change the general shape along with the size, crown and pavilion height, X-Z ratio, Corner size, and Culet size. Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=659.0) |
(https://anim8or.com/resources/asl/assets/E_Track.gif) Download (https://anim8or.com/resources/asl/assets/E_Track.zip) | E_Track Instead of extruding splines along a spline path, this plugin allows you to extrude a mesh shape along a mesh path made out of points. Author: Brian Heath (B_twist) (http://www.anim8or.com/smf/index.php?action=profile;u=10736) Related Links: External Website (http://www.seahorsediveclub.com/Club%20Photos/Forms/AllItems.aspx?RootFolder=%2FClub%20Photos%2FAnim8ion&View={91233F6A-64AD-433C-930F-4426210C992A}) |
(https://anim8or.com/resources/asl/assets/f8ce.gif) Download (https://anim8or.com/resources/asl/assets/f8ce.zip) | F8ce An an8 version of MakeHuman, allowing you to easily create a variety of humanoid characters. Author: Bob_I_Ts (http://www.anim8or.com/smf/index.php?action=profile;u=62) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=3410.0) |
(https://anim8or.com/resources/asl/assets/jet_engine_blades.gif) Download (https://anim8or.com/resources/asl/assets/jet_engine_blades.zip) | Jet Engine Blades A script that makes jet engine blades. Define the number of blades, height, width, center width, size, and inner & outer rotation. Author: Monex (http://www.anim8or.com/smf/index.php?action=profile;u=295) [Website (http://www.lassespcsite.frac.dk/)] Related Links: CG-Nation Blog (http://cg-nation.com/community/index.php?action=blog;blog=36;entry=431) | About Page (http://www.lassespcsite.frac.dk/jetblade.php) |
(https://anim8or.com/resources/asl/assets/Lshape.gif) Download (https://anim8or.com/resources/asl/assets/Lshape.zip) | LShape Lets you create an L-shaped block or corner block. You can customize the Horizontal and Vertical Length and Width of each leg and the depth. Author: BOB_I_Ts (http://www.anim8or.com/smf/index.php?action=profile;u=62) [Website (http://homepage.ntlworld.com/w.watson3/)] Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=15.0) |
(https://anim8or.com/resources/asl/assets/paraboloid.gif) Download (https://anim8or.com/resources/asl/assets/paraboloid.zip) | Paraboloid Creates a paraboloid shape. Lets you specify the size, height, and vertical and horizontal segments. Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: CG-Nation Blog (http://cg-nation.com/community/index.php?action=blog;blog=28;entry=169) |
(https://anim8or.com/resources/asl/assets/polygon.gif) Download (https://anim8or.com/resources/asl/assets/polygon.zip) | N-Sided Polygon Good replacement to the N-Gon tool if you're just looking to make an N-sided plane. Options for the number of sides and toggle a center division in the parameters. Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: CG-Nation Blog (http://cg-nation.com/community/index.php?action=blog;blog=28;entry=169) |
(https://anim8or.com/resources/asl/assets/perlint.gif) Download (https://anim8or.com/resources/asl/assets/perlint.zip) | Random Terrain Generate a randomly shaped terrain. Author: Felipe Manga Related Links: Forum Topic (http://www.anim8or.com/main/index.html) |
(https://anim8or.com/resources/asl/assets/ring.gif) Download (https://anim8or.com/resources/asl/assets/ring.zip) | Ring shape Simple and useful ring/pipe primitive. Author: NickD (http://www.anim8or.com/smf/index.php?action=profile;u=776) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=1864.0) |
(https://anim8or.com/resources/asl/assets/roof.gif) Download (https://anim8or.com/resources/asl/assets/roof.zip) | Roof (Triangular Prism) Simple roof primitive in the form of a triangular prism. You may define the height, width, depth, and the offset of the peak. Author: BOB_I_Ts (http://www.anim8or.com/smf/index.php?action=profile;u=62) [Website (http://homepage.ntlworld.com/w.watson3/)] Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=15.0) |
(https://anim8or.com/resources/asl/assets/slope.gif) Download (https://anim8or.com/resources/asl/assets/slope.zip) | Slope Create a simple slope with the option to customize the height, length, and starting/ending width and scale. Author: BOB_I_Ts (http://www.anim8or.com/smf/index.php?action=profile;u=62) [Website (http://homepage.ntlworld.com/w.watson3/)] Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=15.0) |
(https://anim8or.com/resources/asl/assets/spring.gif) Download (https://anim8or.com/resources/asl/assets/spring.zip) | Spring Original spring shape by Steven Glanville. You may define the sides, diameter, offset, segments, cycles, and spread. Author: Steve (http://www.anim8or.com/smf/index.php?action=profile;u=1) [Website (http://anim8or.com)] Related Links: Anim8or.Com Scripts Page (http://anim8or.com/scripts/index.html) |
(https://anim8or.com/resources/asl/assets/stair.gif) Download (https://anim8or.com/resources/asl/assets/stair.zip) | Stair Shape Easy way to make a staircase by defining the number of steps, length, height, and width. You can also specify if the stairs need a solid support or not. Author: BOB_I_Ts (http://www.anim8or.com/smf/index.php?action=profile;u=62) [Website (http://homepage.ntlworld.com/w.watson3/)] Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=15.0) |
(https://anim8or.com/resources/asl/assets/star.gif) Download (https://anim8or.com/resources/asl/assets/star.zip) | Star Create a nice star . You can define the number of beams, radius, thickness and more parameters. Author: Syziph Related Links: Forum Topic (http://www.anim8or.com/ubb/Forum6/HTML/000107.html) |
(https://anim8or.com/resources/asl/assets/teapot.gif) Download (https://anim8or.com/resources/asl/assets/teapot.zip) | Utah Teapot The classic 3D teapot (http://en.wikipedia.org/wiki/Utah_teapot). Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=665.0) |
(https://anim8or.com/resources/asl/assets/tetrahedron.gif) Download (https://anim8or.com/resources/asl/assets/tetrahedron.zip) | Tetrahedron Simple tetrahedron shape (3-sided pyramid). Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: CG-Nation Blog (http://cg-nation.com/community/index.php?action=blog;blog=28;entry=169) |
(https://anim8or.com/resources/asl/assets/torus.gif) Download (https://anim8or.com/resources/asl/assets/torus.zip) | Torus Torus or donut, you call it! Author: Tyson Collins [Website (http://tysonc.net/)] Related Links: none |
(https://anim8or.com/resources/asl/assets/uvblock.gif) Download (https://anim8or.com/resources/asl/assets/uvblock.zip) | UV Block Builds a cube with proper UV coordinates on all sides. If viewing from the front viewport you can adjust the UV scaling for all the sides when using the non-uniform scale tool. Author: BOB_I_Ts (http://www.anim8or.com/smf/index.php?action=profile;u=62) [Website (http://homepage.ntlworld.com/w.watson3/)] Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=15.0) |
(https://anim8or.com/resources/asl/assets/addloop.gif) Download (https://anim8or.com/resources/asl/assets/addloop.zip) | Add Edge Loop More than just creating an edge loop based on an edge you select, it will try to deform it based on the surrounding mesh (make it contoured). Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=1105.msg8144#msg8144) |
(https://anim8or.com/resources/asl/assets/applyselection.gif) Download (https://anim8or.com/resources/asl/assets/applyselection.zip) | Apply Selection Select some points, store it, then apply that selection later on! Author: Claude (http://www.anim8or.com/smf/index.php?action=profile;u=6) Related Links: (http://) |
(https://anim8or.com/resources/asl/assets/BooleanOperations.gif) Download (https://anim8or.com/resources/asl/assets/BooleanOperations.zip) | Boolean Operations Create a wide variety of shapes easily using this plugin! Enables union, intersection and subtraction. Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) with the help of NickE (http://www.anim8or.com/smf/index.php?action=profile;u=399) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=2507.0) |
Download (https://anim8or.com/resources/asl/assets/ComplexCleanUp.zip) | Complex Cleanup This script will delete completely useless edges and points and it will select the points and edges you should edit to keep your mesh clean. If you want to make nice clean models, you should run this script everytime you finish a model (especially if you are a beginner...). Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=1105.msg8892#msg8892) |
(https://anim8or.com/resources/asl/assets/connectpoints.gif) Download (https://anim8or.com/resources/asl/assets/connectpoints.zip) | Connect Points Connect two points of the same face and split the face in two (a knife tool) Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=1105.msg10490#msg10490) |
Download (https://anim8or.com/resources/asl/assets/CopyFaces.zip) | Copy Faces Do you need to duplicate a part of your mesh? You can use this tool. It does basically the same like the Detach Faces command, but the original shape is not changed. Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: |
(https://anim8or.com/resources/asl/assets/deform.gif) Download (https://anim8or.com/resources/asl/assets/deform.zip) | Deform Mesh Deform a mesh based on strength, diversity, smoothness, seed, and refresh attributes. Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=1105.msg10829#msg10829) |
(https://anim8or.com/resources/asl/assets/edgespin.gif) Download (https://anim8or.com/resources/asl/assets/edgespin.zip) | Edge Spin Just select an edge that splits a 4+ sided polygon and spin it! Author: Claude (http://www.anim8or.com/smf/index.php?action=profile;u=6) Related Links: (http://) |
(https://anim8or.com/resources/asl/assets/growsel.gif) Download (https://anim8or.com/resources/asl/assets/growsel.zip) | Grow Point Selection Select one or more points and this script will select the next nearest connected points to them. Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=1105.msg9635#msg9635) |
(https://anim8or.com/resources/asl/assets/reducer.gif) Download (https://anim8or.com/resources/asl/assets/reducer.zip) | Poly Reducer (Reduce Triangles) Reduces a triangulated mesh anywhere between 1%-95% while preserving materials and UV Coords. Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=1105.msg11651#msg11651) |
Download (https://anim8or.com/resources/asl/assets/ReloadTextures.zip) | Reload Textures Reloads all textures in your project. Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=2715.0) |
(https://anim8or.com/resources/asl/assets/removeloop.gif) Download (https://anim8or.com/resources/asl/assets/removeloop.zip) | Remove Edge Loop Select an edge loop and this script will remove it, keeping the mesh intact. Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=1105.msg8144#msg8144) |
(https://anim8or.com/resources/asl/assets/removeuseless.gif) Download (https://anim8or.com/resources/asl/assets/removeuseless.zip) | Remove Useless Removes useless points on an edge that don't serve any function. This usually occurs when merging faces. Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=1105.msg8144#msg8144) |
(https://anim8or.com/resources/asl/assets/selectsim.gif) Download (https://anim8or.com/resources/asl/assets/selectsim.zip) | Select Similar Select one or more meshes, faces, edges, or points and this script will find similar structures and select them as well. Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=1105.msg9635#msg9635) |
(https://anim8or.com/resources/asl/assets/snap2pnt.gif) Download (https://anim8or.com/resources/asl/assets/snap2pnt.zip) | Snap2Pnt Set a point as the snap-to point, then snap any number of other points to it! Author: Claude (http://www.anim8or.com/smf/index.php?action=profile;u=6) Related Links: (http://) |
(https://anim8or.com/resources/asl/assets/triangulate.gif) Download (https://anim8or.com/resources/asl/assets/triangulate.zip) | Triangulate Mesh Creates a triangulated copy of a mesh. Author: Claude (http://www.anim8or.com/smf/index.php?action=profile;u=6) Related Links: Archived Forum Topic (http://www.anim8or.com/ubb/Forum6/HTML/000143.html) |
(https://anim8or.com/resources/asl/assets/twopointdistance.gif) Download (https://anim8or.com/resources/asl/assets/twopointdistance.zip) | Two Point Distance Finds the distance between 2 points. Author: CobraSpectre (http://www.anim8or.com/smf/index.php?action=profile;u=20) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=252.0) |
Download (https://anim8or.com/resources/asl/assets/UniversalMirror.zip) | Universal Mirroring Need to mirror several shapes at once? This plugin can do that. It can also mirror groups, subdivisions, parametric meshes, spheres and more... Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=2887.0) |
(https://anim8or.com/resources/asl/assets/unsub.gif) Download (https://anim8or.com/resources/asl/assets/unsub.zip) | Unsubdivision Script Have you ever permanently converted a subdivison object to mesh and wanted to convert it back, or picked up a previously subdivided mesh from someone else? Reverse it using this tool! Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=1105.msg9368#msg9368) |
(https://anim8or.com/resources/asl/assets/untriangulate.gif) Download (https://anim8or.com/resources/asl/assets/untriangulate.zip) | Untriangulate Mesh Untriangulates a triangulated mesh! Author: NickE (http://www.anim8or.com/smf/index.php?action=profile;u=399) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=1122.msg9351#msg9351) |
(https://anim8or.com/resources/asl/assets/c_export.gif) Download (https://anim8or.com/resources/asl/assets/c_export.zip) | .C Exports the same C language data structures that Anim8or's built-in exporter does. Does not export animations. Author: Steve (http://) [Website (http://anim8or.com/)] Related Links: Scripts Page (http://www.anim8or.com/scripts/index.html) |
(https://anim8or.com/resources/asl/assets/celestia_export.gif) Download (https://anim8or.com/resources/asl/assets/celestia_export.zip) | Celestia (.cmod) Format for a popular space simulation program. Does not export animations. Author: Selden (http://) [Website (http://www.lepp.cornell.edu/~seb/)] Related Links: Celestia Website (http://www.shatters.net/celestia/) | Scripts Page (http://www.anim8or.com/scripts/index.html) | Archived Forum Topic (http://www.anim8or.com/ubb/Forum6/HTML/000129.html) |
(https://anim8or.com/resources/asl/assets/msh_export.gif) Download (https://anim8or.com/resources/asl/assets/msh_export.zip) | Orbiter Mesh (.msh) Exports to a format compatible with the Orbiter program Author: Urwumpe [Website (http://orbithangar.com/searchauth.php?search=Urwumpe)] Related Links: Orbit Hangar (http://orbithangar.com/searchid.php?ID=2698) |
(https://anim8or.com/resources/asl/assets/roblox_export.gif) Download (https://anim8or.com/resources/asl/assets/roblox_export.zip) | Roblox (.mesh) Exports to the .mesh format compatible with a popular brick-based game. Does not export animations. Author: Gamer3D [Website (http://www.roblox.com/User.aspx?ID=6621)] Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=1314.0) | Roblox Website (http://roblox.com/) |
(https://anim8or.com/resources/asl/assets/STL_export.gif) Download (https://anim8or.com/resources/asl/assets/STL_export.zip) | STL (.stl) Exports the basic triangulated models into a regular .stl file. Does not export animations. Author: Raxx [Website (http://an8.the-meadow.net)] Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=4136.0) |
(https://anim8or.com/resources/asl/assets/vrml_export.gif) Download (https://anim8or.com/resources/asl/assets/vrml_export.zip) | VRML (.wrl) Exports objects to the Virtual Reality Modelling Language. Author: Paulo (http://www.anim8or.com/smf/index.php?action=profile;u=721) [Website (http://perso.orange.fr/paulo54/)] Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=3168.0) |
(https://anim8or.com/resources/asl/assets/obj_export.gif) Download (https://anim8or.com/resources/asl/assets/obj_export.zip) | WaveFront Object (.obj & .mtl) Updated to include more material properties and multiple materials per mesh. Does not export animations. Author: Steve (http://) [Website (http://anim8or.com/)] Updated by: MrProtek (http://www.anim8or.com/smf/index.php?action=profile;u=15843) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=4463.0) |
(https://anim8or.com/resources/asl/assets/x_export.gif) Download (https://anim8or.com/resources/asl/assets/x_raxx_export.zip) | .X (by Raxx) This is an updated .X exporter that is a mix of the best of the other .X exporters, and may be more compatible with your program of choice. Does not export animations. Author: Raxx [Website (http://an8.the-meadow.net/)] Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=4135) |
(https://anim8or.com/resources/asl/assets/x_export.gif) Download (https://anim8or.com/resources/asl/assets/xjoecooning_export.zip) | .X (by Joe Cooning) Exports to the popular DirectX/D3D format. Does not export animations. Author: Joe Cooning (http://www.anim8or.com/cgi-bin/ubbmisc.cgi?action=getbio&UserName=Joe+Cooning) [Website (http://joecooning.galekus.com/)] Related Links: Archived Forum Topic (http://www.anim8or.com/ubb/Forum6/HTML/000003.html) |
(https://anim8or.com/resources/asl/assets/x_export.gif) Download (https://anim8or.com/resources/asl/assets/xzaidon_export.zip) | .X (by zaidon) Based on Joe Cooning's script, this version exports to the popular DirectX/D3D format but imitates the Conv3DS output structure. Does not export animations. Author: zaidon (http://www.anim8or.com/cgi-bin/ubbmisc.cgi?action=getbio&UserName=zaidon) [Website (http://groups.yahoo.com/group/gp500mate/)] Related Links: Archived Forum Topic (http://www.anim8or.com/ubb/Forum6/HTML/000003.html) |
(https://anim8or.com/resources/asl/assets/x_export.gif) Download (https://anim8or.com/resources/asl/assets/xcranny76_export.zip) | .X (by Cranny76) Exports to the popular DirectX/D3D format. Remarked to be a rough draft version. Does not export animations. Author: Cranny76 (http://www.anim8or.com/cgi-bin/ubbmisc.cgi?action=getbio&UserName=Cranny76) [Website (http://)] Related Links: Archived Forum Topic (http://www.anim8or.com/ubb/Forum6/HTML/000105.html) |
(https://anim8or.com/resources/asl/assets/x3d_export.gif) Download (https://anim8or.com/resources/asl/assets/x3d_export.zip) | WRL (.x3d) Exports to the .X3D file format. More info here (http://freewrl.sourceforge.net/) Author: hermetic_cab (http://www.cyworx.com) |
(https://anim8or.com/resources/asl/assets/ani2lux.png) Download (https://anim8or.com/resources/asl/assets/ani2lux%200.1a.zip) | Ani2Lux v0.1a Alpha version of a converter that allows you to export Anim8or scenes to the LuxRender file format. Author: Dwsel (http://www.anim8or.com/smf/index.php?action=profile;u=1481) [Website (http://dwsel.deviantart.com/)] Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=4027.0) |
(https://anim8or.com/resources/asl/assets/ani2pov.png) Download (http://texel3d.free.fr/projets/progs/ani2pov.zip) | Ani2Pov v0.92 Converts between several different file formats Author: Texel (http://www.anim8or.com/smf/index.php?action=profile;u=32) [Website (http://texel3d.free.fr/index.html)] Related Links: Ani2Pov Web Page (http://texel3d.free.fr/projets/ani2pov/) | Mirror Download (https://anim8or.com/resources/asl/assets/ani2pov.zip) |
(https://anim8or.com/resources/asl/assets/ASLEditor.png) Download (https://an8.tcj.rocks/resources/Com/ASLEditor/3.5/ASLEditor_v3-5.ZIP) | ASL Editor 3.5 Excellent development tool for ASL scripts. Author: Kubajzz (http://www.anim8or.com/smf/index.php?action=profile;u=8) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=2178.0) |
(https://anim8or.com/resources/asl/assets/bvh2an8.png) Download (https://anim8or.com/resources/asl/assets/bvh2an8.zip) | BVH2Anim8or Converts a motion capture file (BVH) to Anim8or Author: NickE (http://www.anim8or.com/smf/index.php?action=profile;u=399) Related Links: Forum Topic (http://www.anim8or.com/smf/index.php?topic=3953.0) |
A new one,EdgeSpin and 2 old ones still
usefull,I think.
Details in the README files.
usefull,I think.
Any reasons why they weren't added?
Thanks.
Advanced Plane Plugin
Author: Vobla
Link: http://www.anim8or.com/smf/index.php?action=dlattach;topic=131.0;attach=123
Description: Plugin is more advances than built-in plane plugin: you can devide it to segments;
History:
+Parameters added allowing non uniform scaling, tnx BOB_I_Ts
+ Plane is facing up the Y axis;
+ Texture coords are counted well, tnx Claude;
+ Drawn points are reused;
+ Icon updated;
Neiro has sent me a PM regards one of the Plugins that is on my GUI
I think It was one of Kubajzz`s creations but I can`t remember anyway here it is below....
if (parameter("Rafter Centers") == 0 && parameter("Gables %") <100)
$roof.OpenFace(0,4); /* soffits */
$roof.VertexN($roof.AddPoint(($lx/2, $tail_height-$fascia+0.06944, $wz/2)));
$roof.VertexN($roof.AddPoint((-$lx/2, $tail_height-$fascia+0.06944, $wz/2)));
$roof.VertexN($roof.AddPoint((-$lx/2-$overhang, $tail_height-$fascia+0.06944, $wz/2+$overhang)));
$roof.VertexN($roof.AddPoint(($lx/2+$overhang, $tail_height-$fascia+0.06944, $wz/2+$overhang)));
$roof.CloseFace();
$roof.VertexN($roof.AddPoint(($lx/2+$overhang, $tail_height-$fascia+0.06944, -$wz/2-$overhang)));
$roof.VertexN($roof.AddPoint(($lx/2, $tail_height-$fascia+0.06944, -$wz/2)));
$roof.CloseFace();
$roof.VertexN($roof.AddPoint((-$lx/2-$overhang, $tail_height-$fascia+0.06944, -$wz/2-$overhang)));
$roof.VertexN($roof.AddPoint((-$lx/2, $tail_height-$fascia+0.06944, -$wz/2)));
$roof.CloseFace();
$roof.CloseFace();
it will add soffits on roofs with hips if #parameter("Rafter Centers", int, 24, 0, 24); is zero.[img] http://Your.externallink.com/Image.jpg [/img]
I am very curious is someone could try to create a scrip that allows camera position&animation to be exported and imported. That would be freakin' usefull. At my work I also use AE for compositing, and sometimes would be helpfull to be able to export the camera animation and then import it to Ae.
If someone could do such a script, please let me know.
Thanks.
Hello Raxx,
why don't you add my modeling tool set here or atleast mention it here, though some of them get replaced by new function of anim8or and i am happy with that but what about other?
// Set position to a random position based on frame number.
float $x, $y, $z;
randseed(frame);
$x = frand()*100.0;
$y = frand()*50.0 + 50.0;
$z = frand()*100.0;
$position = ($x, $y, $z);
