General Category => General Anim8or Forum => Topic started by: onespirit5777 on November 26, 2008, 06:34:34 pm
I'm still new to this. When I animate something it will move backwards a little and then in the direction I wanted it to go. I look at the key frame and it will show it in the opposite direction and I didn't do it.
If you check the graph you will see the parameter path.
You can fix it from there by adjusting the points.
thank you
