General Category => General Anim8or Forum => Topic started by: animation-nation on November 24, 2008, 10:18:50 am
Once again, I'm new to anim8or and I want to learn how to use it. So how good are the tutorials at this website? Will I learn a lot from all the tutorials?
Doing the tutorials on this site will give you the basic understanding on how the model, rigg and animate using anim8or. There pretty helpfull when you just get started. I suggest to go through the eggplant and simple walk tutorial. Because these give an easy explanation on the basics. After that try to model something easy yourself.
O, I almost forgot: read the manual (http://anim8or.com/manual/index.html)!!! Most of the answers on your questions about using anim8or can be found here. This is a recommendation for every starter.
Google is great, search for tutorials cause there are loads out there, also check out animanon.com for extra help and basic tuts if needed. Link in bottom left corner <-------- over there.
A good way is to play with Anim8or and try everything and see what happens, you can always undo (Ctrl + Z)
