General Category => ASL Scripts => Topic started by: vobla on January 16, 2008, 03:55:41 pm
Hi,
When I tried to run it, I got "This application has failed to start because jper62.dll was not found. Re-installing the application may fix the problem.".
Anyway, I found it on the web and placed in the same dir as *.exe and app lounched, but whenever I load *.png or *.jpg 'Convert' button doesnt get enabled.
*.bmp works fine ;)
And please add the line for the dimension requirements in readme.txt, it may save some time for someone ;)
EDIT: for the *.bmp I get unexpected result (picture seems to be a bit streched, edges cut).
It looks like the .dll jpeg62 is neeeded to run that application. Where did you get a copy? I'll add it to the .zip file. (I didn't write plugicon so I wan't aware that it needed this library.)
Here you are ;)
http://www.driverskit.com/dll/jpeg62.dll/1412.html
Cheers
i have the corona and jpeg62 driver both included when made backup for null's app pluginicon.zip (http://homepage.ntlworld.com/w.watson3/main/files/plugicon.zip)
there is also sample bmp with correct dimensions that the user can edit and over wright
