General Category => General Anim8or Forum => Topic started by: GeniusAtWork on July 27, 2008, 09:02:21 pm
Title: filling problems
Post by: GeniusAtWork on July 27, 2008, 09:02:21 pm
I make closed shapes and edge loops and when I go to the edit toolbar all the edit options are blank. So I go into build and fill it but lots of lines appear in the shape. This is stopping me from being able to use edge loops and create faces. and also when I join these faces, a transperent face appears joining the the gap. ???
Title: Re: filling problems
Post by: hihosilver on July 28, 2008, 02:34:03 am
Could you display an image of the issue?
Post by: GeniusAtWork on July 28, 2008, 04:11:46 am
how can i get a screen shot of my image because when i render it, it doesn't show the lines. the lines are connecting the points to one another and edge is not a single line but i cannot get the line the shape i want it so that i can leave it as a single line.
Post by: Mr.Smeagol on July 28, 2008, 05:28:20 am
Press printscreen button on your keyboard, go in paint, edit>paste, save as jpg, upload to imageshack or anywhere else, and post the link or image itself here.
Post by: GeniusAtWork on August 07, 2008, 02:23:52 am
sorry it took so long. Haven't been able to get to computer in a while. here is the image
Post by: hihosilver on August 07, 2008, 03:04:49 am
Basically your issue is that the fill tool creates tri's.  Those "lines" (edges) are created by anim8or because it doesn't know how you want the edges to flow, so it simply fills the shape.  What I often do is merge all the faces then use the cut tool to cut edges the way I want.  Or, just begin with the add edge tool and draw what you want instead of using the spline tool.
Post by: GeniusAtWork on August 07, 2008, 03:19:06 am
It worked!
Thanks for the help. ;)
