Author Topic: morphs & figures  (Read 7274 times)
glorfon
    • Muse
morphs & figures
« on: July 02, 2008, 12:16:47 pm »
I made a figure of a humanoid and I had given the object morphs for lip sinking but now in scene mode I can't find the morphs.  How do I access them? Can I?
YeeEAP!
Re: morphs & figures
« Reply #1 on: July 02, 2008, 03:10:54 pm »
either expand the menu tree at the bottom of the screen (left of the timeline), or use the graph editor (the button for that is on the right-hand end of the top menu bar).  if you open graph editor and select the object, then the morph should show up in the properties list on the left of the graph.
hope that helps :)
- colclough
mak
« Reply #2 on: July 02, 2008, 07:30:34 pm »
dont know if this is the problem but try this add the figure in scene mode then go back to the object and select a morph,then go to the scene and open the menu tree and see if theyer there
realisim is for reality
headwax
    • Headwax's Website
« Reply #3 on: July 02, 2008, 08:57:00 pm »
Add figure in scene mode. At first there won't be any morphs.
Then add the object that makes the figure into the scene mode.
Delete   that object.
The morphs will magically appear on your figure.
Presto :)
glorfon
    • Muse
« Reply #4 on: July 03, 2008, 11:48:37 am »
Thanks for your help but I discovered another technique once I made the figure the parent of another object the morphs apeared.
YeeEAP!
