Author Topic: texture problum  (Read 9473 times)
madm0nkey
texture problum
« on: June 11, 2008, 10:11:01 pm »
 >:( I am making a car but when I try to put on the texture its plain white( the side of the pic is plain white)
I have tried using the uv tool but no matter which way I turn it or how much I shrink it its not there. see the s.
attachments.
Re: texture problum
« Reply #1 on: June 12, 2008, 04:11:39 am »
This is a hard problem to address.  To begin with though, do you have viewing textures enabled? (View>Preferences... then select textures in the viewport and file output section.)
Re: texture problum
« Reply #2 on: June 12, 2008, 08:03:06 am »
Which anim8or version are you using here? Because in v0.97 i had this problem too sometimes and the texture only way to be seen when i rendered.
falloffalot
Re: texture problum
« Reply #3 on: June 12, 2008, 04:31:57 pm »
Have a look at the link it`s a video tut that I think may help.
http://www.mp3d.info/video/heli.zip
madm0nkey
Re: texture problum
« Reply #4 on: June 12, 2008, 10:55:38 pm »
 I had done every thing that was in that video. I have texturing enabled, and I am using anim8tor v095.
 so any other tips. I think I will pull each part of the texture im using apart( window doors, ect) and apply them to the model not together but in pieces.
« Last Edit: June 12, 2008, 11:02:18 pm by madm0nkey »
madm0nkey
Re: texture problum
« Reply #5 on: June 12, 2008, 11:12:53 pm »
oh ok fixed it my bad now I fill so stupid. ok after you select the part you want to put the texture on don't dis select  it click the UV tool right away and the texture shows up.
thanks for the help.
