Pages: 1 [2]
Author Topic: sketch-based modeling and Anim8or  (Read 36641 times)
MatejMakesStuff
  • Model, Animate, Play!
Re: sketch-based modeling and Anim8or
« Reply #15 on: October 12, 2023, 12:52:21 pm »
Woah that's creepy!
ianross
« Reply #16 on: April 01, 2024, 08:48:19 am »
I created the following images, using an AI application,monstermash and anim8or. 8)
Firstly, I asked the AI app to create a woolly mammoth side view. Then I traced around the image of the mammoth in monstermash and it inflated into a 3d model.
The 3d mammoth was then imported into Anim8or, the 2d backdrops were created in the AI online app.
« Last Edit: April 01, 2024, 08:49:03 am by ianross »
2020 Hindsight
« Reply #17 on: April 02, 2024, 08:32:43 am »
What AI did you use? I've never seen a mammoth with tusks pointing down :)
I guess you treated the tusks like legs in monstermash to get two of them? Or did you add them manually?
It looks good! Is this part of a larger project?
ianross
« Reply #18 on: April 03, 2024, 06:02:39 am »
Thank you Hindsight you are right the tusks should be pointed outwards, please see the below changes.
There are many apps that can be used to create AI, here is a websites that is a good starting place.
https://perchance.org/ai-text-to-image-generator
The mammoth images have been created for educational interest for the anim8or forum. 8)
« Last Edit: April 03, 2024, 06:04:35 am by ianross »
2020 Hindsight
« Reply #19 on: April 03, 2024, 09:56:01 am »
Thanks for the AI link. I've just had a little play with it - it is good! Although it seems to get a bit confused with fingers (see attached image).
Your mamoth looks right to me now.
I wondered if you created the tusks like the legs in monstermash. But I guess you must have added them manually?
Pages: 1 [2]
