Author Topic: Creating edge loops  (Read 12130 times)
danielstritt
  • Eternally a newbie
Creating edge loops
« on: January 25, 2022, 10:16:59 am »
Is there an easy way to create a new edge loop in an object? The only way I see is divide each edge to create a new vertex in the middle then connect each one manually.
Thanks,
Daniel
Re: Creating edge loops
« Reply #1 on: January 25, 2022, 06:55:42 pm »
You can also use the Topographical Knife tool to do this. Or you can first select the edges that you want to connect, then use the Edit->CutEdges command to split theme exactly in the middle, and then connect the middle points with the Add Edge tool.
Gyperboloid
« Reply #2 on: March 15, 2022, 05:32:04 pm »
I'm kinda late, but since it's never too late... ;)
If the goal is to create an edge loop and not just to connect edges, if the topology ofcourse allows to do so , use the Quad Ring Select command from Edit->Select menu and then use the Connect Edges command from the same Edit menu.
danielstritt
« Reply #3 on: March 17, 2022, 04:22:07 pm »
Thanks, I never thought of that. It's not too late since I am still using the software after getting the new book about it.
