Author Topic: Minor bug fixes  (Read 10512 times)
Gyperboloid
Minor bug fixes
« on: February 09, 2020, 04:30:48 am »
If there's any free time available for some bugs, that are maybe easy to fix :
  • "l" hotkey in Point Editor still splits solids. Not needed, since the command exists in Object Editor in the Build menu.
  • Object's folder name can not be changed. If possible, to make it editable.
  • Tool tips in Options menu. Make it activated permanently, remove from the menu (helps to see if a tool will be selected ).
  • Configure - > UI : Hitting Cancel sets the Fast Select Mode in upper tool bar to the different value of what it was before opening the window, always ( from off to on and from on to off )
Re: Minor bug fixes
« Reply #1 on: February 09, 2020, 07:05:22 pm »
Thanks, I'll look into these.
