Author Topic: How do you create a new point these days?  (Read 17045 times)
Kyle
« on: June 04, 2019, 09:39:24 pm »
As in starting fresh on a new mesh? It used to be shift, but it seems to have changed?
Re: How do you create a new point these days?
« Reply #1 on: June 05, 2019, 06:46:58 pm »
To start a new spline, select the Add Edge tool in the Point Editor. Then Shift+Click-Drag in an empty space to add the first edge.
Kyle
« Reply #2 on: June 05, 2019, 09:15:16 pm »
Either I'm misunderstanding something or that does not work.
To me, a new spline would be the tools you use for lathe, which is not what I mean.  (those dont require holding down anything anyway, just clicking and dragging normally)
But when I hit the add edge button and hold shift while dragging, literally nothing happens.
Edit: oops, I see now. I had to make sure I wasnt on the shaded modes. It appears to work now.
Follow up question, it looks like points go way further than where my mouse is, is this just something I need to get used to in the latest version or can I put it back to precisely following where my cursor is?
« Last Edit: June 05, 2019, 09:18:59 pm by Kyle »
