Author Topic: Art keeps crashing...  (Read 9844 times)
xalener
« on: April 12, 2008, 04:51:20 pm »
I have a large scene, an room with pillars and bannars in it. The floor is marble, and I wanted to add a glossy atribute to it. As soon As I go to render it, anim8or crashes immediately. It shouldn't be too hard to recreate. All you need to do for it to work is to add atributes to a mesh with textures (the floor had a bump, specular, and a diffuse map.)
Could it be the specular map?
Re: Art keeps crashing...
« Reply #1 on: April 13, 2008, 01:58:53 am »
the anim8or class specular glossy attribute should be able to use all maps.  To test your theory though, I'd try only applying one map at a time and try rendering, and see if it crashes or not.  Then you could figure out the issue.
beyond_3rd_dimension
    • My anim8or gallery in facebook
« Reply #2 on: April 13, 2008, 02:01:28 pm »
I have tried it in my laptop in every combinations... ''glossy + texture'' seems to work just fine for me..
I trust only two persons, ME and NOT YOU
DressedForSucess
  • ive decided to wear my thorn of crowns
« Reply #3 on: April 15, 2008, 01:29:56 am »
yeah, ive had similiar problems ... though my sets are massive, set to cast shadows (ray traced) and anim8or shuts down ... its annoying.
i think it comes down to the amount of memory who pc has ...
apparently, ive been recommended a 2g memory and a ... 3000mb? graphics card (oir some biger graphics card than i have currently, which is a 128mb )
so, its probably due to the fact your pc is slow ...
its like quicksand, once the 3d has a hold of ya, theres no gettin out
« Reply #4 on: April 15, 2008, 06:39:07 am »
I believe glossy works in combination with the rough value of the material, which is standard 32. Having a glossy effect with rough at 32 will cost alot of memory. I suggust setting the rough to something like 200 or higher, i believe it goes up to 1000. That might solve the problem.
