Author Topic: connecting a point to an edge, removing points  (Read 6560 times)
Hypure
« on: January 01, 2016, 11:06:54 pm »
Is it possible to connect a point to an edge creating two edges?  And Is it possible to remove points without losing an edge?
Re: connecting a point to an edge, removing points
« Reply #1 on: January 02, 2016, 05:01:18 am »
Yes, select the edge, then do a shift/Z to cut the edge this will give you another point
Yes again, move the point you wish to remove very close to an existing point, then do a shift/L and type in an appropriate number for the tolerance (default 0.50) and it will merge the two points together. If it does not, either move the point closer or use a higher number.
« Last Edit: January 02, 2016, 05:02:26 am by kreator »
Hypure
« Reply #2 on: January 02, 2016, 03:50:54 pm »
That helps, thanks kreator.
