Author Topic: Spheres, cubes and cylinders point edit help  (Read 5453 times)
Bugsulv
« on: July 21, 2013, 09:43:51 am »
Greetings.
I am an absolute beginner so sorry if this is stupid question, but how can I edit sphere, cube or cylinder points? I set it to display wireframe, select point edit, but I can't see, and thus, select, any point. With primitive mesh, for example, I can see and edit the points perfectly.
KyleSan
Re: Spheres, cubes and cylinders point edit help
« Reply #1 on: July 21, 2013, 10:06:21 am »
Hi there,
You'll have to select the shape you want to edit in Object/Edit mode. Then Build>Convert to Mesh.
When you go to Object/Point Edit mode you should be able to see and select the individual points and edit then as you want.
Bugsulv
« Reply #2 on: July 21, 2013, 10:10:25 am »
Thank you! Works perfectly
KyleSan
« Reply #3 on: July 22, 2013, 05:47:56 am »
Only a pleasure. Could I suggest giving the manual a look over?
http://www.anim8or.com/manual/index.html
This specific topic is covered under the "Mesh vs. Panametric Shapes" section.
When in doubt read the manual haha.
