Author Topic: Problem in Anim8or's "brother', Terranim8or  (Read 5592 times)
misa443
« on: June 23, 2013, 01:16:37 pm »
Hello everyone!
I followed the tutorial on how to make 3d surface meshes in Orbiter Space Flight Simulator. In Terranim8or, I need to build terrain from the grayscale map of SRTM terrain heights data and it needs to be the same size as the grayscale map (which is in JPG). Everything is okay, but when I try to subdivide the terrain by rounding it says that it hasn't enough memory. What should I do?
Re: Problem in Anim8or's "brother', Terranim8or
« Reply #1 on: June 23, 2013, 01:40:38 pm »
If you really need to subdivide it, then you can subdivide it within Anim8or. In Terranim8or, save the terrain to a file, load it up in Anim8or, select the mesh and go to Build->Convert to Subdivided or Build->Subdivide Faces...
misa443
« Reply #2 on: June 23, 2013, 02:08:03 pm »
I meant that I want to round it by going to Build-Subdivide-Rounding (tension 0), but it says not enough memory.
