Author Topic: changing materialls on the fly  (Read 7763 times)
rellik420
    • youtube channel
« on: June 04, 2011, 01:55:31 pm »
seems like i cant do this with morphe targets but i could just be doing it wrong.
say u have a sphere with a drawn on face. the 1st drawing is a normal face the 2nd is a smile, 3rd is a frown and so on.
ill keep messing with it but it will help if some1 knows a good way to do it.
h
  • Neirao
Re: changing materialls on the fly
« Reply #1 on: June 04, 2011, 02:56:25 pm »
hi  :)
you can use same trick for "animated backgrounds":
tutor:
&NR=1
other sample:
basically you need use the "visibility key" in scene mode.
or
render multiples modes (with each texture face)and after edit the video in a editor!
i hope then this help you! ;)
« Last Edit: June 04, 2011, 03:09:03 pm by neirao »
rellik420
    • youtube channel
« Reply #2 on: June 04, 2011, 04:00:11 pm »
thanks neirao.
that actually looks like a lot more work than it should be. so i think i will try and do it in an editor.
what i want to do is have something drawn in my video. so it would be like  looking at someone draw on a piece of paper with a pencil. im sure it would be easier to animate the actual movements of the hand anc pencil then manually make what is drawn in a video editor.
thanks for the help.
h
