Author Topic: How do I insert images with transparency?  (Read 5906 times)
TheRetroZombie
  • I do crap animations.
    • Youtube Channel
« on: August 06, 2010, 07:21:43 pm »
Is there a certain file type I have to use. I tride several but doesn't seem to work. I use Paint.net.
X
ADSohr
Re: How do I insert images with transparency?
« Reply #1 on: August 06, 2010, 08:15:49 pm »
If you are trying to use a texture that has transparent parts I believe you can use a transparency map(read about them in the manual) with that texture to make those areas clear or semi-clear, depending on the grayscale level of the trans. map. One note; I'm pretty sure I've seen that the ART raytracer does not support transparency, so transparent areas will show up as shadows.
thebigomlet
« Reply #2 on: August 08, 2010, 10:59:00 am »
i think u can just get a regular texture, put it on ur object, and change the transparency in the materials() hope this helped
« Last Edit: August 08, 2010, 11:06:38 am by thebigomlet »
